4l65/3.23-th350/3.73 results
Old 03-05-2007, 11:42 AM
chris93266's Avatar
Default 4l65/3.23-th350/3.73 results
my previous best was a 12.2@116 with a 2.0 60'. the old setup was a pro yank 3600 extreme converter, built 4l65, and 3.23 gear. I went out to the track on saturday with the new setup: th350, edge 4000 stall, 3.73 gears and got a new best by .6 seconds. my first pass was an 11.6@117 with a 1.6 60' even with hitting neutral on the 2-3 shift for about 1 second. i ended up with a best mph of 118.53.
the motor is exactly the same except the tune is off now because i changed the injectors and have not fully tuned it. i used the same wheels/tires on both passes.
i have to say i am extremely satisfied with the swap. i cannot say enough good things about this converter from edge.
here are the time slips...
Old 03-05-2007, 05:26 PM
raymond mckinney's Avatar
Damn, that's a good drop in ET's sounds like money well spent.
Old 03-05-2007, 06:22 PM
Old Drag Racer
Smokinstorm's Avatar
I need to do that TH350 swap in my car that I've been putting off for two years......
To prove my point I've thrown almost 5 grand at 4l60's during this same time period to keep them going just because I wanted a damned 4th gear in my race car. What an idiot I am.
Old 03-08-2007, 09:22 PM
Restricted User
98Z28CobraKiller's Avatar
What did it cost you for the tranny and the stall? How much power is the trans theoretically supposed to support?
Old 03-09-2007, 10:24 AM
chris93266's Avatar
the same type tranny/builder held up to a 10.0@145 in a friend's car and made about 100 other passes on the street. he parted the car out before the tranny blew. tranny was $500 and the converter was $450.
Old 03-09-2007, 12:50 PM
Restricted User
Damn Dude, that's the kind of deal that I need to get on. If I could get all of the stuff required to switch over for under $1200.00 I would be all over it.
Old 03-09-2007, 01:09 PM
chris93266's Avatar
you can do it for under $1200 if you have the hookup on transmissions, use a $450 edge converter, drill stock flexplate holes to 3/4", build your own crossmember, splice speedo and wheel speed sensors(kills abs), use junkyard th350 dipstick and insert heater hose to lengthen, use junkyard trans. lines & cut stock ends off and use rubber hose to connect the two, & use stock driveshaft.
Old 03-09-2007, 02:12 PM
Restricted User
That's what I am talking about. I am aggresively exploring this avenue.
Old 03-09-2007, 03:46 PM
chris93266's Avatar
well i am cheap as H E L L so if you want any tips on a cheap way to do a certain part of the swap just pm. most people that get this deep into modding have pockets just as deep. i don't care how deep or shallow my pocket is, every dollar i don't spend is another dollar i don't have to make again before retirement.
Old 03-11-2007, 09:18 PM
slimcracka's Avatar
i wanna know a back to back comparison like this with just boltons ...
Old 03-14-2007, 02:47 AM
skinnies's Avatar
How in the heck did you only 60ft a 2.0 before?
Old 03-14-2007, 02:52 AM
Mr.MartyStone's Avatar
Same thing I'm wondering
Old 03-14-2007, 07:43 AM
V6 Bird's Avatar
So in other words yes it could be done, but the only reason you get it done was because you hacked it in there?
Old 03-14-2007, 01:38 PM
chris93266's Avatar
i had 3.23 gears and the yank converter just didn't do the trick.
Old 03-14-2007, 01:40 PM
chris93266's Avatar
no, I did not hack anything into my car lol. i spent a little over his $1200 budget. i'd say i'm around the 1300-1400 range, but i sold my old trans/converter setup for $1900.
Old 03-14-2007, 02:13 PM
skinnies's Avatar
I still can't believe with a stall and 442rwhp you could only do a 2.0 60ft on good tires. Did it bog every pass? I think a lot of your gain was just 60ft and better hooking, which could've been done with the 4l60e.
Old 03-14-2007, 03:43 PM
chris93266's Avatar
the pro yank extreme 3600 nitrous converter is very tight. it would not stall or flash past 1500rpm. i dead hooked and did not bog. the th350 has a higher first gear, which is better because there isn't such a difference in the split between the gears.
who said this couldn't have been done with a 4l60? i know someone here locally doing 1.5x through a 4l60. the point is that the converter/gear/trans swap netted me these gains with the same tires and motor setup(other than injector change).
Old 03-14-2007, 05:35 PM
SEB
SEB's Avatar
I pull 1.5 60fts on my 4L60E & stock 10bolt
Old 03-14-2007, 11:00 PM
skinnies's Avatar
I know the PYE is a tight converter, I got it going in my car, I'm just suprised with that much power you still couldn't get a better 60ft than a 2.0, makes me honestly think something was wrong.
The th350's 1st gear isn't as steep as the 4l60e so it will require more stall to get the same 60ft.
You did get nice gains, I'm not bashing your decision on the tranny swap or anything, I just think something had to be wrong before if traction wasn't an issue, a 2.0 60ft with the stall(even a tight stall) and that much power just isn't right.
Old 03-15-2007, 12:09 AM
chris93266's Avatar
i thought my torque curves looked pretty good. i also thought something must have been wrong, but i couldn't find anything wrong with it.
Quick Reply: 4l65/3.23-th350/3.73 results
