i hate 13.10s....
Old Mar 22, 2007 | 09:43 PM
nickdotcom's Avatar
Originally Posted by monsterbreather
get a handheld and get your throttle body ported and polished... car will still drive like it does, but at w/o throttle,you will be in the 12s.
are you serious? handhelds hurt more than help and are a waste of money
and p&p TB stands for ported polished throttle body
Old Mar 22, 2007 | 10:09 PM
LC2's Avatar
LC2
if you try to hand held tune that car youll be using #7 piston as a paper weight..you just need to swap that converter or 373s or both ..yanks will give you some awsome 60 footers but i can see you need the car daily so use a vig.2800-3000.......that rear will take you to roll cage times with an auto..
Old Mar 22, 2007 | 10:24 PM
chrs1313's Avatar
multiple 1.57 60fts on the stock rear...took the cover off last week to change the fluid and the magnet barely had any metal on it...i was really suprised for 43K miles...have fun get the m/t's that is what i am getting now...
Old Mar 23, 2007 | 09:55 AM
nickdotcom's Avatar
i think i''l get the yank SS3200 or maybe SS3600
Old Mar 23, 2007 | 05:30 PM
monsterbreather's Avatar
diablo tune and a ported and polished t/b got me from 13.4 to 12.92.. period. steert tires and a 273 rear.. thats my personal experiance.
Old Mar 23, 2007 | 06:55 PM
nickdotcom's Avatar
i've already got the TB and im not getting a handheld.. period
Old Mar 24, 2007 | 11:28 AM
damn you never said you had the tb done?? well good luck there, may be you will get into the 12s one day..
Old Mar 24, 2007 | 11:31 AM
5_02ls1's Avatar
on a lid catback car handhelds are ok but anything beyond that = major detonation.get a tune if anything.my hpp3 worked good when car was stock now its only used for shift tuning
Old Mar 24, 2007 | 11:37 AM
5_02ls1's Avatar
doing an intake lts ory and cutout and 3.73s with a mail order tune i gained 1.1second and 6 mph.so im leaning towars a tune the 323s are not a bad gear at all.
Old Mar 24, 2007 | 11:49 AM
they do work good and alot can be changed.its a great start to a close to stock ls1 and a cheap way to set stuff how you like it and more than likely DROP A TENTH OR TWO in the quarter for under 300 bucks.. my diablo tune pinged at wot but i straightened it out. profs in the pudding for me!!
i know the high stall is a sweet option but for the price and pullin the trans out,daily drivin with it and the extra heat,,,its alot easier to drop you quarter times with a tune first.
Old Mar 24, 2007 | 04:05 PM
s346k's Avatar
consider your raceweight. not everyone has their chassis weight down to ~3100 lb. i'd guess most stock auto cars to be 3,400-3,500 lb. the extra weight makes the car harder to move (hence the slower times..) also adding stress to the rear.
however, my full weight auto car went low 1.6x 60' MANY MANY times with no trouble. the car only experienced ONE wheel hop launch in my possession - which resulted in my quickest time on street tires. rolled out easy then dropped the hammer when it shifted to second gear - was a bad idea on radials @ the track - i thought for sure i was going to break it, evidently i got lucky.
10 bolts will take some abuse in auto cars if you DO NOT LET IT WHEELHOP. wheelhop is your enemy with any rear, ESPECIALLY the wimpass 7.5" 10 bolt.
Old Mar 26, 2007 | 05:35 PM
  #32
chrs1313's Avatar
chassis weight is not 3100 that would mean i weigh 265 lbs, the car is at about 3210 i know not that much higher but 100 lbs is 100 lbs...i know my 60fts were on great da days but none the less low 1.60s can be expected and i guess i am just lucky for now with my 10-bolt...
just stating that that 60ft can be done with the 10-bolt not that i run it all the time...
and i only experienced lifting both tires once...usually it is only one
