Trex,4400 Stall A3,with 3.73's and 28" Tires?
Justa asthe title says just wondering if you Trex guys think this will work??
Ported TB
LS6
EWP
Dynatech LT's
ORY
Powerbond Pulley
TH400 RMVB
PTC 4400 Stall
3.73's
28" TiresWill this be good for mid 11's??Looking to run right around 11.50's Cam Only RW around 3550
BTLFEDSS
Ported TB
LS6
EWP
Dynatech LT's
ORY
Powerbond Pulley
TH400 RMVB
PTC 4400 Stall
3.73's
BTLFEDSS
I was thinking of doing a similar cam but I have a 4l60e with a 4k stall. It seems that you guys are saying a bigger stall, is that due to his tranny being a th400 or is that the best size stall no matter what tranny? Also, I was going to run a 4.56 gear since all I have local is a 1/8mi track, is the 4.30 just a minimum gear for the cam or is that what gear would be best for the setup he mentioned?
with the ms3 i run a 4400 in a 4l60 4.10 and 28's and the set up seems to work well.......... might go to 4.30's to maximize rpm at the end of the track.... but with a Th400 wher u can much bigger stalls with an all motor setup you want to 5k or higher to take full advantage of the motor!
Retired Street Racer
LS1Tech Co-Founder
Cams like that need converter and rpm, so you'd have to run it and see what that converter really does with that combo.
I ran at like 3400 raceweight, 240/244 cam, 4800 8" converter, TH400, 4.10's, 28 slicks, and heads, etc., and went 10.92@122.5 on a 1.48. Car was still pretty lazy and needs a bit more converter for motor. I would run a 4.10 minimum with that cam, and 4.30's would probably be even better but I'm staying with my 4.10's.
If it was a 4l60e setup, I would go 4400-4800. Yes, the bigger stall is needed in the th400 due to the different gearing. There is no "best" stall speed. Everyone's setup is different, and weight, tire size, and gear all affect what the converter actually stalls to. I have a Yank PT4400 in my 4l60e, and with a 3.73 gear, 26" slick, 340rwhp, & 3040lbs, it flashes to 4800-5000, but kicks *** at the track. The 5500 I recommended should be a round about start for his car if he stays on motor, and it should be an 8" converter. If he were to spray it, the 4400 would work good if it is a 9"-9.5" converter.
