Dissapointed
I played with this calculator a bit:
http://www.wallaceracing.com/8th-quarter.php
Your 1/4 Mile ET is 14.61 seconds computed from your vehicle 1/8th ET of 9.351 seconds.
Your 1/4 Mile MPH is 97.85 MPH computed from your vehicle 1/8th MPH of 78.91 MPH.
I am betting bogging KILLS compared to spinning on a 60'.
It's just most of my runs have been from a roll and I have NEVER lost to a C5, and I always put a car or two on the 05+ GT's (they are known to trap 102+ in 5-speed manual form), I even put 1-1.5 cars on an 08' from 60-95 with a clogged cat! (GM replaced it).
Well, I guess I need to just all but side-step it from 2-2500 once in my life (only done 1 real burnout in it, and that was to smear a copperhead that was slithering across the road) and see what she can do!
So, everyone agrees a 2.36 on a BOG would cost at LEAST 2mph?
on that calculator. My best 1/8 is 8.6 @ 83 and it tells me that I SHOULD run 13.47 @ 102.9 when, in actuality, my best so far is 13.30 @ 105.6. Yes that bog will drop you 2 mph. Romp on it; 10 bolts are a dime-a-dozen, you can get another one at a junkyard. You can't get a good E.T. at a junkyard...
on that calculator. My best 1/8 is 8.6 @ 83 and it tells me that I SHOULD run 13.47 @ 102.9 when, in actuality, my best so far is 13.30 @ 105.6. Yes that bog will drop you 2 mph. Romp on it; 10 bolts are a dime-a-dozen, you can get another one at a junkyard. You can't get a good E.T. at a junkyard...Then again, it was off for a few other vehicles I punched up.
Experience verified? Would make me feel better if someone did the SAME thing and got the same results.
on that calculator. My best 1/8 is 8.6 @ 83 and it tells me that I SHOULD run 13.47 @ 102.9 when, in actuality, my best so far is 13.30 @ 105.6. Yes that bog will drop you 2 mph. Romp on it; 10 bolts are a dime-a-dozen, you can get another one at a junkyard. You can't get a good E.T. at a junkyard...Its off by a .1 and 1 mph on my slip.
Yeah, I was slipping the clutch pretty good from 1500 rpm. Completely weak launch. That and granny-shifting is what I think cost me the 2-3mph, no?
The tires did hook awesome, on the 1-2 shift I only got a little squeek from them (TC was off, yes, I did do that right!).
My question is this. I bounced off the rev limiter right before passing the score-sign. At what rpm should I shift into 4th to avoid this but not compromise my performance?
Wouldn't 3500rpm be an instant sacrifice to the 10-bolt gods? I am scared of it, I blew it once just backing out of the driveway with the clutch half out at 800rpm.
Basically 2500rpm and then let the clutch out just slow enough to say I didn't drop it?
What rpm should I shift into 4th to avoid hitting the rev-limiter going through the traps?
Last weekend running on 89 Octane i was still getting 105~106mph traps (don't ask)...
My method isn't perfect but it's been working... 2200rpm and slipping the clutch out quickly.
Everything else I've tried has just embarassed me in front of everyone at the track...(2.6 ~ 3.3 60fts suck)
Did you say your at the limiter in 4th going through the traps? Is this with a 3.42 gear?
Yes, the car on the street has killed Z4M's, tied with every C5 I have run, and puts 1.5+ car per 30mph of acceleration or so on the 05+ GT's (from 60-90 is 1.5+ cars on them and so on). From a roll it feels STRONG!
Yes, I shift slow. When on the street a shift will cost me about 5-8 feet every time a shift is performed. Is this slow enough to kill mph?
I think without my lame driving the car would trap 105 easy.
