New Drag Radial Personal Best: Full Weight + some streetcar setup 408/L92 results
#81
You can't really compare your car to his since I imagine your car is alot lighter. What does your weigh? Do you have A/C, power steering, etc? Taking off accessories makes a big difference. I'm not defending, because obviously he has some bugs to work out. But comparing your car to his is definitely apples and oranges.
110lb driver vs a 250lb driver...
her car weighs under 3300.... she has alot of iWeight mods.
I already stated what is wrong with the combo.....
1. Heads are too big for NA.
2. Intake is restrictive
3. Nitrous wasnt on a WOT Switch on the 6.6 run
4. Car weighs alot.
If I can get it to run consistant 6.5's with a nice wheel tire/slick/MT325 style combo on a 150 shot I will be content.
#82
1 Post
#83
1 Post
4. Car weighs alot.
4. Car weighs alot.
![Engarde](https://ls1tech.com/forums/images/smilies3/engarde.gif)
#84
4. Car weighs alot.
4. Car weighs alot.
#85
Actually it is very logical to compare his car to mine, mine is a little lighter but his 408 should make up for my weight difference. I still have power steering, my car is not totally gutted but the AC is out. Still, instead of all the excuses the problem should be fixed.
Me, I know my car has more in it, and I know where the problem is....converter is slipping too much. Once I get that fixed I can go with a 3.90 gear and be easily in the 10s easy with no more weight removed.
#87
How is the intake too restrictive? Thats a GMPP intake, it should flow every bit as good as a FAST. There's plenty of cars out there with that intake (and FAST) that are really fast. And don't waste your money on a sheet metal intake, your motor doesn't need it. Those intakes are for for motors like what the Six Speed Inc. car has. Your motor would fall flat on its face with a sheet metal intake.
#89
#91
The car was at 91kpa... now it is at 93-94kpa after more tuning and a very little bit of smoothing work from Brian Lohse at Real Performance Motorsports in Lewisville. More or less a proper gasketmatch. The intake is restrictive, I had no intent on going with a sheetmetal. There are too many other parts that would be smart.
Really what I would love to be able to do is pull the motor out as a longblock and put it in a stock T-56 car and see what kind of mph it does. I know weight is a factor.... but how much?
#92
Also, I saw a picture of your engine bay in another thread. Have you taken that maf off? I not, you probably should. That maf is really choking that 408.
These 408's really like speed density tunes. You stand a chance of picking up some power there.
#94
It'a not a HUGE factor at the times you are running.
Keep in mind, my car is pretty much full weight as well.
Specially with my 270lb fatass driving it.
Trading for those truck heads(317) might not be a bad idea, but I'm not quite sure if I would trade straight up.
#95
The rule of thumb is .1 off your 1/4 et per 100 lbs. Rotating mass is even more. And getting weight off the front end helps moves the instant center back....a problem that us heavy turds with iron blocks tend to have (instant center being too far forward).
#96
I dont get where so many in this thread are saying the elbow is hurting this car THAT much. WHere is this info coming from? Is it an "opinion" or more CRAP re gurgitated from message boards?
I have a similar setup on a 383 LT1 that runs BETTER than this car with a Monoblade TB.
So wheres the proof?
Also when you guys are saying his runners are too big, is the runner LENGTH beind considered?
This car has some issues no doubt, his intake setup aint the problem.
When a buddy of mine put down 525 to the wheels with an afr headed 408 with a FAST 90/90 through a 4L80E and a 12 bolt....something is up.
#97
