Drag Racing Tech
I might have a SERIOUS problem....need help
Old Oct 19, 2008 | 11:08 PM
passionforracing69's Avatar
Default I might have a SERIOUS problem....need help
I was at PIR this weekend, I have a '00 black z28 bone stock. I've made around 100+passes on Bandimere and Julesburg in Colorado, and I know I can race. My camaro had a 15.0 first run with a 2.4 60' I launched at 2000 RPM's, second pass was a 14.9' and I launched at 2500' RPM with a 2.2 60'. Does that seem slow to you guys? Could there be something wrong with my car or do I just need to go to the store and buy some vagisil because I got my feelings hurt?
Old Oct 19, 2008 | 11:36 PM
silverbeast's Avatar
you need a set of tires bad. If you can get that 60' down to a 1.9 range it will make a lot of difference.Btw what is your elevation at the track you were running?
Old Oct 19, 2008 | 11:45 PM
jsteele90's Avatar
wow my bone stock 90 gsx ran a 14.2 at 93 with a 1.76 60 foot you need to get those 60s down.
Old Oct 20, 2008 | 12:18 AM
the track is like 100' above sea level, and my tires grabbed I didn't spin with a 2500RPM launch at all. Even though the 60' is bad it doesn't account for a freakin' 15 second quarter.
Old Oct 20, 2008 | 12:27 AM
jetlag's Avatar
You might know you can race...but what do you know about actually driving? Hahah
That made me laugh out loud. Yes, the 60ft time is why you ran a 15 second pass. If all you are doing is spinning down the track..guess what..it makes you go slower...
Old Oct 20, 2008 | 08:27 AM
98CamZ28's Avatar
Well, in his post he said he didn't spin, so, must not be it then
Old Oct 20, 2008 | 09:17 AM
LM97Z's Avatar
What did it run @ Bandimere? I know that track ain't 100ft. above sea level lol, what track is PIR? & what was the MPH, sure you could use better tires, but i've seen guys run 2.0s, even 1.9s on crappy radials, even if you got the 60ft. down to 2.0, that would be 14.6 @ best, thats why we really need the MPH, both 1/8 & 1/4, are you sure you weren't spinning? I ran 14.5s @ 97 in my fairly stock 97 LT1 with a 2.4 60ft. @ 1500ft. track.
Old Oct 20, 2008 | 12:29 PM
BETTER THAN YOU's Avatar
depends on where you are at in texas that car would run faster because we are no where close to the elevation where you are at. just work on getting that 60 ft. down.
Old Oct 20, 2008 | 06:41 PM
well I can get the 60' down, the trap speed was 74 1/8 and 94 1/4. but what's a good launch rpm for a stock z28? I didn't run this Camaro at Bandimere.
Old Oct 20, 2008 | 07:07 PM
som1sc's Avatar
Make sure it dont have a 4.8 in it
Old Oct 20, 2008 | 07:31 PM
Krazy98Z28's Avatar
is the car tuned for high elevation?
Old Oct 20, 2008 | 07:46 PM
01blackz28's Avatar
94 mph something is causing a MAJOR POWER LOSS
Old Oct 20, 2008 | 08:32 PM
LM97Z's Avatar
Your car is in sad shape if 94 mph is all it ran at 100ft. altitude, are you sure about that altitude?? where is this track at, what state?
Old Oct 20, 2008 | 08:46 PM
quiet_storm98's Avatar
were one of your plug wires unplugged or something??? There is no way your trap speeed and times should be that slow if you were only 100ft above sea level, the first time i went to the track i had 2.2 60's and i still was running 13's plus my car is a heavy *** convertible which had a race weight of almost 3900lbs. Has your car been tuned or anything? that could be the problem since you were at a high elevation before
Old Oct 20, 2008 | 08:57 PM
InEEdSPEED's Avatar
take it to a shop or somethin dude check the compression n if its firing on all the cylinders, check for vacumm leaks, somethin is seriously wrong
Old Oct 22, 2008 | 12:11 PM
so there were some developments the past couple of days, I started to practice my launch, and realized after 3800 rpm I have a loss a power, not a huge loss, but noticeable. Then I start hearing a tick at certain RPMS but only under load... wtf?
