Drag Racing Tech
wrapping out 3rd in the 1/4?
Old Oct 20, 2008 | 01:01 PM
my2kTA's Avatar
Default wrapping out 3rd in the 1/4?
This past Friday I took a trip out to the track and only made two passes before deciding to call it a night due to the fact that track prep was horrible and no one was hooking AND I was banging on the limiter due to wrapping out 3rd before the end of the 1/4 (by a couple hundred feet).
Ive been reading and searching all weekend on the solution and am under the impression that I can extend my gearing by going with a taller tire (28"). Is this the easiest/best/correct solution?
The car is stock cubes, forged internals, 5.3L 2.5 heads, 228/232 .571/.588 113LSA cam. full bolt-ons.
Drivetrain is FLT LVL5 tranny, Yank 3500/2.5str, 3.73s. Tires are 275/40/17 Nittos
I downloaded the tune from my VCM even though the tuner said it was locked (not sure if this means its not) and see that the shiftpoints for 1->2 and 2->3 are set for 5200 which equates to 6000 on the scanner. 3->4 is set at 8160 which I believe is set so that I stay in 3rd through the 1/4.
Old Oct 20, 2008 | 03:57 PM
BADD SS's Avatar
Converter slippage, trans going out? Someting doesnt sound right, I mean even on a 26 inch tall tire, youre 3rd gear should top out around 123 mph or so on a stock size tire.
Old Oct 20, 2008 | 06:16 PM
my2kTA's Avatar
Trans has around 1k on it. The converter is a different story as it was in the car when it was my DD for 4 years. Maybe has 25k on it, but I would only hit the track once or twice a month and even then was making 3 or 4 passes a time.
ill head over the the trans section of the board and start reading up there. Thanks for the reply!
Old Oct 20, 2008 | 06:34 PM
dab2pds's Avatar
third gear with 3.42 and a vigilante 3600 i dont top out in third til 136+ with 275/35/18 and 6600 shift point
Dave
Old Oct 20, 2008 | 07:45 PM
BADD SS's Avatar
Dave
Yeah, with a 3.42 and 6600 shift, iwas figuring on his gears 3.73 and a 6200 rpm rev limit.....
Old Oct 20, 2008 | 10:23 PM
BadBandit69's Avatar
i run a 3.73 and a 26" tire and have never had problems with hitting the limiter. although i'm shifting at 6800. whats your limiter set at?
Old Oct 20, 2008 | 11:06 PM
my2kTA's Avatar
From the HPTuners file under the WOT Shift RPM vs Shift - Performance
1->2 5200
2->3 5200
3->4 8192
When looking back at the scan of my run it shifts just about 5.8k for the 1->2 but goes all the way up to 6.8k for the 2->3
edit: ive reviewed the scan for about the 15th time while posting this and am now only counting two gears (1->2 shift) which would mean im wrapping out 2nd and not third....which makes more sense. time to look else where.
Thanks for all the help everyone
Old Oct 22, 2008 | 01:02 PM
02 BLK WS6's Avatar
Sounds like 2-3 flare up.
Old Oct 22, 2008 | 01:26 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Third gear is good for 124-128mph. Your converter is too loose, trans is going out, or something. You should be shifting that cam at 6500 at least.
