Drag Racing Tech
Pin on VFN sunoco pics?
Old Oct 22, 2008 | 09:52 AM
2FAST4U's Avatar
Default Pin on VFN sunoco pics?
I know there are a ton of these hood pics. However not many pin on pics. And I need a underside pic. I would like to see the VFN sunoco and the wide sunoco.
I am trying to see the clearance in the front. so I can see if the piping will clear. I have seen the underside of the bolt-on and the hood latch area is in the way. As I am looking at dueing a TT intercooler with a LARGE singe center out. So the intercooler may need to lay back alittle but would rather keep in straight up for better air. Either way a 4" intake pipe over the radiator support is going to be tight. As the radiator straight up but could go shorter on the radiator if I had to.
Thanks
Old Oct 22, 2008 | 10:05 AM
Camaro396's Avatar
Ill try to snap an underside picture of mine today. They are just a basic shell though. What you see on the outside is exactly how its shaped underneath.
Old Oct 22, 2008 | 12:07 PM
promod1955's Avatar
I've got a car in the shop im building with the vfn pin on wide sunoco. From the front edge of the radiator support (pinch weld area) to the bottom of the hood is 4 5/8". If thats not enough room you can notch the rad. support and get a lot more room.
Old Oct 22, 2008 | 09:00 PM
Z8'S's Avatar
I have that same setup and have the Sunoco Wide pin on .clears great.
Old Oct 23, 2008 | 08:01 AM
troopercar's Avatar
Old Oct 23, 2008 | 11:15 AM
2FAST4U's Avatar
That is exactly what I was looking for. Thanks
Old Oct 23, 2008 | 04:22 PM
Z8'S's Avatar
My extended /Wide Sunoco has nothing on the bottom .
Old Oct 23, 2008 | 05:05 PM
Camaro396's Avatar
This should help you out a bit.
The hood:
The underside:
Old Oct 23, 2008 | 05:28 PM
2FAST4U's Avatar
Z8'S Do you have any pics of your hood? As the pic of the Twinturbos with that huge intake tube made me think it was no problem. Then I see two pics of hoods with supports under them. And you say yours doesn't have those?
Old Oct 23, 2008 | 11:50 PM
promod1955's Avatar
The car I was referring to has the foam supports as well. The radiator support is inbetween the foam supports shown in camaro 396's pics.
Old Oct 24, 2008 | 09:41 AM
Z-RATED94's Avatar
Originally Posted by troopercar
That's got to be the best looking hood out there for a 4th Gen. Just my opinion, but I'm right 99.9 percent of the time.
Old Oct 25, 2008 | 06:19 PM
Z8'S's Avatar
My Bad!! I just checked and it has the same bottom as the ones posted above.
