Drag Racing Tech
How is the DA calculated?
Old Sep 15, 2003 | 07:48 PM
Durien's Avatar
Default How is the DA calculated?
Can some one explain this whole weather thing to me??
THANKS!
Old Sep 16, 2003 | 03:19 AM
68LSS1's Avatar
Default Re: How is the DA calculated?
Air temp plus barometric pressure plus humidity equal density altitude. Air density decreases as altitude increases (less molecules per cubic centimeter as altitude increases). Here's a link to a DA calculator. The terms it uses are temp, dew point (humidity) and station pressure (barometric pressure at your altitude). I'm a aircraft mechanic and when your doing a turbine engine performance run you have to use a chart for that engine using temp and altitude to ensure you can make "rated" or N1 of the day power for your "location."
Old Sep 16, 2003 | 07:06 PM
Durien's Avatar
thanks!
