What should I do...?
So here is my question. What can I do with $5,000 to get the biggest chunk of time off of that 12.21? Here is what I'm willing to do. I will do anything to the car, except for weight reduction, because I want to keep it really nice to drive around and have it function just like a stock car still. Also, I am willing to take off performance parts that I've already put on in order to get better ones, if that's cost effective. I will sell those parts, but I don't want to sell the stock parts, I'm keeping all of them.
So, first of all, I'm going to want a built tranny if I upgrade my power at all, so that's $2,000 (FLT level 4) gone immediately. So I will have $3,000 for go fast parts.
What do you suggest doing to get the most possible time out of it? Is there any possible chance of hitting 10's with that?
Thanks for your help?
With just the rear end and some real tires you will be in the 11's and with a 150 shot you could prob get 10's if not bottom 11's.
With a rear end, some tires and a cam you could prob get bottom 11's also.
Either way a rear end should be in your future.
And no, I don't really go to the track that much. It's usually just to measure new mods or if I think I can do better than last time, so a couple times a year probably.
. Basically going to the track for me is just to measure the car. I don't build the car for the track, I just use it as an instrument and to have some fun
. So what would you suggest as far as what to do now then? I have two options so far that seem viable. Heads/Cam or Nitrous/Cam. I kinda prefer the heads/cam combo if they are similar in performance. I just feel strange about nitrous. Plus I like the power always being there rather than only sometimes and then being able to run out, etc. Anyway, what do you think?
if i had to do it over i'd keep my nice car probably and do just like i said above with a small cam and rear and spray the thing hard!
So.... I think I like the H/C plan... I can always make the rear end stronger later and get better tires. And that would make for a really mean street car. So anyway, with the approximately $3000, what combo would you suggest? I think I like the 228 to 230 or maybe 232 range for cam, and for heads I'm not really sure.
it will sound good and should make around 600hp if sprayed a decent amount...
