Drag Racing Tech
Will a SS3600 Yank??
Old Oct 29, 2008 | 04:54 PM
99_ls1_z28's Avatar
Default Will a SS3600 Yank??
Will this converter put me in the 7's?? If not , will a PT4000 will? I currently have the SS3600 with me, but not installed. Just wanted to make sure before I put it in. Also will the 275-40-17 BFG drag radials be able to hook? Mods are in sig, I have added a ported TB but have not made a run with it yet. The car is not tuned also. But at the moment I can do a converter or a tune, wich should I do first. My goal is to run 7's as soon as possible.
Old Oct 29, 2008 | 06:29 PM
c0ncEpT's Avatar
As long as you can hook the 3600 converter alone will get you there.
Old Oct 29, 2008 | 06:31 PM
Scoggin Dickey's Avatar
LS1TECH & Trucks Sponsor
I don't think it will. .4 in the 1/4 from a converter would be very possible, but in the 1/8 is pushing it
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Old Oct 29, 2008 | 07:16 PM
99_ls1_z28's Avatar
I thought it would, cause I am not doing too good on the 60ft. Dropping .3 in the 60ft would almost get me there right??
Old Oct 29, 2008 | 07:25 PM
1slo_camaro's Avatar
From: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
yea but to lower you 60s you need to hook not raise you stall RPM. you need better tires. or instead of the converter try some LCA and rolac. brackets. start getting the power to the ground and you will lower it.
Old Oct 29, 2008 | 07:29 PM
chrs1313's Avatar
with traction it is possible but you might need a little weight reduction, another bolt on, or lower DA
Old Oct 29, 2008 | 07:39 PM
99_ls1_z28's Avatar
ok, I get it. You don't think the BGF's will hook??
Old Oct 29, 2008 | 07:41 PM
Silver2000WS-6's Avatar
I personally think you could. Here is a link to my car/results with a yankss3600 https://ls1tech.com/forums/drag-racing-results/1001083-how-did-i-do-boltons-ss3600.html. I ran like a 8.2 with a 2.00 60' before the converter then went 7.71 with a 1.71 60' after the converter. Keep in mind that there was about a 20 degree temperature difference and sway bar deletion between the runs. I also was on bfg drag radials before the converter and et radials after but the car hooked on the bfg's before the converter. I am very pleased with my converter and I think I will be able to get into the 7.6's with a little practice.
,Chase
Old Oct 29, 2008 | 08:23 PM
Magnet's Avatar
yes..with traction..have one in mine and went 7.5's bolt-ons only...
Old Oct 29, 2008 | 08:29 PM
99_ls1_z28's Avatar
Originally Posted by Silver2000WS-6
I personally think you could. Here is a link to my car/results with a yankss3600 https://ls1tech.com/forums/showthread.php?t=1001083. I ran like a 8.2 with a 2.00 60' before the converter then went 7.71 with a 1.71 60' after the converter. Keep in mind that there was about a 20 degree temperature difference and sway bar deletion between the runs. I also was on bfg drag radials before the converter and et radials after but the car hooked on the bfg's before the converter. I am very pleased with my converter and I think I will be able to get into the 7.6's with a little practice.
,Chase
Thats what Im talking about. I ran my best time when the weather was in the 70's. Now its like in the 50's. I just hope I get in the 7's.
Old Oct 29, 2008 | 08:42 PM
I would most definatley be getting a tune in the near future though. Do you have any idea what your car weighs?
,Chase
