Drag Racing Tech
Plug Experts Inside
Old Oct 27, 2008 | 11:16 PM
1fstGM's Avatar
Restricted User
Default Plug Experts Inside
How do these look to you?
Old Oct 28, 2008 | 04:48 AM
JL ws-6's Avatar
Race your car!
Can you cut the threads off where they start, so I can see how far up the fuel is?
How many runs do those have on them, and did you pull threm right at the end of a run (click teh key off and coast off the return road) of did you drive it back to the pits?
Old Oct 28, 2008 | 09:00 AM
BMR Tech2's Avatar
LS1Tech Premium Sponsor
They look good. Maybe a little lean but overall good.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Oct 28, 2008 | 09:12 AM
JL ws-6's Avatar
Race your car!
What heat range/power level are they out of?
Old Oct 30, 2008 | 12:07 AM
1fstGM's Avatar
Restricted User
Sure I can cut the threads off, may be until the weekend until I have some time though.
These had about three passes on them, and I didn't drive back to the pits the last pass (did the previous two though). I was towed back.
Old Oct 30, 2008 | 12:09 AM
1fstGM's Avatar
Restricted User
Heat range was a -10, an NGK plug. Power level was good enough to coast a 9.7 at about 133 MPH. The 1/8th was a 6.1 spinning the tries so I pedaled it a couple times.
Old Oct 30, 2008 | 09:10 AM
Old Geezer's Avatar
http://cochise.uia.net/pkelley2/sparkplugreading.html
Old Nov 2, 2008 | 02:17 PM
1fstGM's Avatar
Restricted User
Thanks!
Old Nov 2, 2008 | 04:57 PM
Old Geezer's Avatar
Lightbulb U R..
Originally Posted by 1fstGM
Thanks!
most welcome.
I use an otoscope to look at the base area of the plug.
An otoscope, if you aren't familar w/ it, is what the dr uses to look in your ears.
Available on the Ebag for not alot of $$.
Mine has rather hi magnification, and has a LED lite source.
WORKS GREAT!
I don't cut the plug up to look at it....
