Skinnys and slicks, Bias ply in front and radial in back?
Hey all wanted to know if there would be any problems running a bias ply front tire (MT Sportsman on a 4 inch summit star) with a radial in the rear (MT et street 275/50R15 on summit star).
Thanks all!
Thanks all!
I run the 8-ply MT Sportsmans up front and Hoosier DR's in the rear on the street and strip without a problem. It's actually a nice, smooth ride on the street and works great at the track.
-Mark
Race your car!
I hear where you've coming from, but for a referance here's some #'s
I know my stock ws6 wheels and tires were about 50 lbs a piece, the bogarts with a 4 ply sportsman was about 26 a piece, not too bad right?
I took the 4 ply sportsman tires off and put a set of DS2 moroso tires on, and the car lost another 25 lbs, 12.5 lbs oer tire! That to me is alot, now add anohter 5 lbs per tire for the 8 ply.
The way I look at a skinny, is that if you are gonna run them, you're takign the risk of losing control easier then you would with a regular tire, so there's risk anyway. The ds2 I went to are suppsoed to be for 3000 lb car,s mine's still about 3350 and I've had no issues with them not holding up the weight, or any of that.
Now I'm looking at an FI setup that's gonna put a bunch of weight in the nose, and I'm not about to take those tires off.
The 8-ply are definitely heavier than the 4-ply, but not as heavy as a stock wheel/tire combo. They are a compromise, but work well for street driving and still work well at the track. I drive my drag setup on the street full time as well as to and from the track (230 miles roundtrip) without a problem, so in that regard they work well.
JL- I think I'll weigh both tires and see what the exact weight difference there is between my skinnies. Both on the same type of rims. I can't think there is a 12lb difference between them. It doesn't feel like it when I swap tires. Unless I'm just <Arnold Schwarenegger voice> "building my muscles up" </voice>
-Mark
Race your car!
We did weigh them before they went on, unless I got some kind of extra heavy 4 ply or a really light set of ds-2's the tires alone were 12 lbs different ber tire.
It was alot, and belive me, I pick up one of the old 4 ply sportsman tires vs the bogart with the ds2 on it and it's scary how close the 2 feel in weight.
But, I'm 6'2 275 and can carry an engine block across a room and a th400 with the converter on up a flight of stairs (out of my basement, where I carried it down to alone) without a problem, so what I consider heavy and light is probably alot different then most.
I have no prob eating crow but if they are indeed 12lbs in difference then I will be doing the same swap as you and going to a bias-ply front. That is, if the tire can hold my weight within the manufactors limit. My car weighs 2950 without me.
-Mark
-Mark
Race your car!
My car's 3350 with me in it and a 1.4 tank of gas. Honestly, I don't even know what teh ds-2 is rated for, but I run them at 35 psi as reccommended, and they are doing fine, no bulging from the weight or anything like that.
Hell they took the front end coming down from a big wheelstand, no problems. Good tire IMO.
