Drag Racing Tech
Dragwheelz.com Is proud to announce Billet Specialties COMP SERIES WHEELS
Old 10-31-2008, 09:37 PM
Dragwheelz.com's Avatar
Default Dragwheelz.com Is proud to announce Billet Specialties COMP SERIES WHEELS
Pricing and weights to follow, After SFI testing.
As of now the weights are lighter then magnums and alumastars......
Old 10-31-2008, 09:48 PM
jmill96Z's Avatar
Is this going to be another wheel that won't fit 90% of the cars on this board?
Old 10-31-2008, 10:20 PM
My street lites fit 90% of the cars here.
So im not sure what your trying to say.
Old 10-31-2008, 10:43 PM
Coal Mining Director
onfire's Avatar
He's saying will they clear factory brakes?
Old 11-01-2008, 12:10 AM
9sec93's Avatar
i dont know pricing but im sure they are not cheap. alot of people that are going to spend good money on a hardcore light weight wheel like that probably have aftermarket brakes already anyways. although i could see alot of people wanting these wheels just from looks alone. they are bad ***!!!
Old 11-01-2008, 12:41 PM
lm7
lm7's Avatar
How will it compare in weight/strength to a bogart bolted P2? also will you guys anodize?
Old 11-01-2008, 03:50 PM
I can Anodize/powder coat yes.
Preliminary scale results weigh Less then a Alumastar 2.0 / Magnum 2.0 front and rear.
Old 11-01-2008, 09:01 PM
phoenix's Avatar
wow these wheels are hot!
Old 11-01-2008, 10:01 PM
And on paper they Should clear.
I will be test fitting after i get back from sema.
Old 11-01-2008, 10:08 PM
YellowB4Z's Avatar
Are there correct rear back spacings available for our cars as well? There is another company that is lacking in the correct back spacing.
Old 11-02-2008, 05:52 AM
Race your car!
JL ws-6's Avatar
I have 2 questions, @1 can you anodize them black, and #2, will there be a beadlock version of the rears available in a 15x12 size, say with a 4.5 backspacing?
(I'm narrowing the rear up probably 4 inches per side, and a 4.5 backspace 15x12 should be right, so I am told)
Old 11-02-2008, 06:37 AM
yes the 7.50 is planned.
Yes they can be anodized, and the beadlock is available on the 15x12" wheel. Also the backspacing is on the list of backspacing. I will know Exact sizing for all soon.
Old 11-02-2008, 07:18 AM
smokeum99ta's Avatar
If pricing is right, bye bye welds and hello new rims. Any ideas on pricing yet?
Old 11-02-2008, 12:52 PM
Race your car!
JL ws-6's Avatar
Sounds good, when the testing is done and pricing is figured out please keep us up to date.
Old 11-02-2008, 01:46 PM
9sec93's Avatar
you will need 5.5" backspacing to keep the rim i n the stock location. with4.5" backspacing the rim will stick out 1" further than stock.
Old 11-02-2008, 03:13 PM
If im Correct The pricing should be around the same as the welds.
Plus you will get my Ls1 discount.
Old 11-02-2008, 05:06 PM
black01_WS6's Avatar
what are the approximate weights? Sizes available? I would like to see a group deal on 15X3.5 and 15X10's with tires. I am sure you could sell quite a few sets that way.
Old 11-02-2008, 05:47 PM
Nimitz87's Avatar
probably comparable with magnums and alumastars...these are not your budget rims and seem to be aimed at the drag only guys.
he said they weigh less than magnum/alumastar 2.0's which I believe are the lightest drag rims out...they are about $1,000 a pop.
Chad
Old 11-02-2008, 07:15 PM
Race your car!
JL ws-6's Avatar
A stock width rear needs a 7.5 inch backspace wheel to keep the tire in stock location. If you narrow the rear 4 inches, that would mean you need a 3.5 inch backspacing to keep the outer edge at the same place with a rim the same width.
So, if I go ta rim that's 2 inches wider and I want all of the added rim on the inner portion, add 2 inches to the backspace, giving me a 5.5 inch backspace 15x12 rim. That makes sense, seems to anyway.
I have over an inch and a half from the control arm to the tire now, and with a different bushing made to sit in the control arm rod end, I should be able to shift the control arms inward another 3/4 of an inch or giving me about a 1/4 inch of space from the tire... just a matter of minitubbing the rear to clear the tires, if needed.
I want to flatten the contact patch out, and go to a beadlock so the sidewall gets worked more evenly in an attempt to get the car to hook harder.
Old 11-02-2008, 07:49 PM
TurboAv's Avatar
You can use this website to play around with tire and wheel sizes with backspacing/offset. You just need to know your stock tire and wheel info and then you input what you want to run and it will show you how far in or out the are from stock and how much more they fill out the wheelwell if a larger size.
http://www.bigcustomwheels.com/rt_specs.jsp
