Drag Racing Tech
My 2000 Camaro Racecar build
Old 01-15-2009, 05:51 PM
  #161
renee00formula's Avatar
Baked, I find it hard to believe you have two fancy late model Fbodies and can't afford 100 dollar a piece greg welds.
Old 01-15-2009, 09:31 PM
  #162
Camaro396's Avatar
Originally Posted by "Q"
Cars looks nice and sounds like a good build. You not doing your own rearend work? Of course it is a pain if your doing it on the ground with the axle in the car.
I've done everything myself on the car so far. The rear end I'm having setup there at our chassis shop at work, cause I'm 19, never done one myself, and I don't trust my car to be my first try. Short of the trans & rear end, everything is done myself.
Old 01-15-2009, 09:32 PM
  #163
Camaro396's Avatar
Originally Posted by renee00formula
Looks slow.
Thanks Reneebop. I know when I park next to your Formula at school, my junk doesn't even compare.
Old 01-15-2009, 09:34 PM
  #164
Camaro396's Avatar
Originally Posted by tomcowle
Whats the ET goals for this car?
I'd like to hop onto the 10 second cam only list. We'll see though. A LOT of work to do.
Old 01-16-2009, 11:53 AM
  #165
BAKED's Avatar
I honestly didn't realize that they were so cheap.....I may get a set sooner than I thought!
Old 01-16-2009, 02:05 PM
  #166
jmill96Z's Avatar
Go for the Bogarts. Worth every penny.
Old 01-16-2009, 02:08 PM
  #167
jmill96Z's Avatar
Originally Posted by Camaro396
New trans/ucc converter is in. Time to load it up on the trailer and head to the chassis shop, to have the driveshaft made, and have the rear end setup.
The car is looking great. Kinda reminds me of mine, but I'm sure your paint is a little better.
Do not be afraid to take risks and do the job yourself. Of course there are certain things you will have to outsource, but the end result will always be better when you do it yourself. Even if it's not "shop quality" you will definately appreciate it more.
Old 01-16-2009, 02:38 PM
  #168
"Q"
"Q"'s Avatar
Yea the trans and rearend is where a lot of guys outsource work on their car no big deal its all good youve done a lot more yourself than most people do.
Old 01-16-2009, 03:03 PM
  #169
Race your car!
JL ws-6's Avatar
Setting the rear end up is easier then you think. You just need to square it to the front wheels (easy to do with a tape measure with the adjustable rear control arms) and center the rear in the car (wasy, hang a string/weight off the 1/4's thru the center of the rim and measure, make sure it's the same on both sides)
Pinion angle, that's pretty easy too, just measure the angle of the pinion output and the angle of the output on the tranny, and make sure the rear end is pointing down a degree with the car on the ground at ride height (use the tranny as the referance to what should be considered zero, rear should be about negative 1 degree from there) and that's about it.
Make sure the control arms are level, or the back on teh rear is lower then the front, and start there.
Pretty easy stuff, if you were local I'd come over and help ya do it.
Old 01-16-2009, 03:14 PM
  #170
jmill96Z's Avatar
There are also jig points on the back of the rear subframe that make good measuring points for squaring the rearend.
Old 01-16-2009, 03:24 PM
  #171
Race your car!
JL ws-6's Avatar
Yes, those work pretty good too. But, I like to measure to the front tires, in case for some reason one ofthose points isn't dead perfect, or whatever.
I know that's how my car was done, and it goes strait as an arrow all day long, 140+ mph and it doesn't pull at all, leaves strait, etc.etc.
Old 01-16-2009, 03:33 PM
  #172
jmill96Z's Avatar
That's the way mine is. Dead straight. I don't really have a bunch of room to work with though. The only level ground I have is in my 1 car garage where I can barely scoot by the car, let alone take accurate measurements.
I think I will be taking mine to Madman's when I get back to make sure everything's good and pick his brain a little.
Old 01-16-2009, 03:35 PM
  #173
Race your car!
JL ws-6's Avatar
Madman is the **** when it comes to chassis setup, if there's anyone that I'd pay to set up a car, he's definately on the top of the list.
  #174
Camaro396's Avatar
No updates, but a few pics of the trans in the car!
Old 01-16-2009, 03:37 PM
  #175
Camaro396's Avatar
Good god this bitch is FILTHY on the underside.
Old 01-16-2009, 03:42 PM
  #176
Race your car!
JL ws-6's Avatar
Power washer, after some simple green is your friend
My next project when all the fab work is gonna have the undercarriage painted with the body, and will be as clean underneath as it is on the top, I'll have that thing on a rotisserie when it gets painted, just so when I get under it to work on it, it's always clean.
Nothing worse then working on something that's got 30 lbs of sludge/crap built up on it. Of course, my car doesn't have 19 k on the body, so I guess it should be pretty clean under there. Not as good as I'd like it to be, but it's not bad
  #177
Race your car!
JL ws-6's Avatar
A set of turndowns off the headers will keep the underside a ton cleaner too.
Old 01-17-2009, 12:00 PM
  #178
1fast98's Avatar
Default ?
i thought cam only meant a camshaft and nothing else? dont you have a big throttle body and intake on the car?
Old 01-17-2009, 12:07 PM
  #179
Krazy98Z28's Avatar
Cam only means the car still runs 98-02 stock heads
You can have all the bolt ons you want
Old 01-17-2009, 06:02 PM
  #180
JL, he means setting the ring and pinion up. Between Trigger and camaro396 they will have no problem setting the suspension up.
Quick Reply: My 2000 Camaro Racecar build
