Drag Racing Tech
29.5 vs 28 in tire
Old Nov 5, 2008 | 07:36 AM
ndfrsd6's Avatar
Default 29.5 vs 28 in tire
Ok here is my current set up ...402 ls2 stroker w/m6 4.56 gears all the front & rear suspension i currently run a 28in tire. My question is im going to a th400 setup and keeping my 4.56's would the 28 be ok or will i have to go to a 29.5 ?
I just dont want to run out of gear and will i have to cut anymore away from my car to get them to fit I am stock height ..
thanks guys
Old Nov 5, 2008 | 07:58 AM
ndfrsd6's Avatar
oh yeah i will probably have a 4800- 5000 stall and trans brake
Old Nov 5, 2008 | 09:58 AM
ndfrsd6's Avatar
anyone ?
Old Nov 5, 2008 | 10:02 AM
BadBoo79's Avatar
You will have to trim the bumper cover to clear a 29"+ tire. How high RPM wise do you want to cross the finish line?
Old Nov 5, 2008 | 10:09 AM
ndfrsd6's Avatar
well i cross right now @ 7100 at the top of 4th
Old Nov 5, 2008 | 10:15 AM
BadBoo79's Avatar
I am running a BBC with a 4:00 gear, similar stall to what you are looking at, 29x10.5W Hoosier (almost 30" diameter), with a Turbo 400 and go through around 6700-6800 rpm.
Old Nov 5, 2008 | 10:26 AM
ndfrsd6's Avatar
so i should be ok with the 29 ? with the 4.56
Old Nov 5, 2008 | 10:28 AM
BadBoo79's Avatar
The 29 should be good. Just keep in mind that sometimes a convertor can cause the car to RPM a little different than expected, depending on how tight or loose it is.
Old Nov 5, 2008 | 10:32 AM
ndfrsd6's Avatar
thank you im new to the auto scene
Old Nov 5, 2008 | 10:45 AM
dlove's Avatar
plan on around 10% slip
put in your info here and have fun
f-body.org/gears/
Old Nov 5, 2008 | 11:27 AM
JL ws-6's Avatar
Race your car!
I have a similar engine setup, and last year n/a with a 28 inch tall radial with a 5000 rpm converter that did have a 9.5% slippage in my 3500 lb car I was trapping around 126 to 127 and going thru the traps at about 6800, I had the shift light set there and it would just barely come on at the end of the track
Had I left the car n/a I was gonna put a set of 4:30's in the car with a 28x10.5S et drag that I went to anyway, I think a 4.56 would probably be on the edge with a 28 inch tire, with a 29.5 you should be fine with it.
I want to go to a 29.5s et drag, a set of 15x12 rims and go back to 4.10 gears (from the 3.73's that I changed to) in hopes to get the car to hook/leave better, and shorten the gearing just a touch, as 3.90's would have been perfect for where I am right now.
Old Nov 5, 2008 | 11:37 AM
ndfrsd6's Avatar
im definitely staying N/A and i weight 3200 race weight and that is coming down this winter ..... thaks for the advice i'll order up the 29.5's ... im excited for the spring ! winter sucks
Old Nov 5, 2008 | 12:05 PM
JL ws-6's Avatar
Race your car!
Those will take some more clearncing I'm sure of that, but they will fit.
I'm actually waiting for a new rim to get SFI certified, once they are I'm gonna order some 15x12 rear beadlock rims (and the matching fronts) and get a set of 29.5x10S et drags, mount them up, and then bring them to my fab guy with a set of wolfe minitubs and a set of wolfe adjustable spring perches, and tell him to make it fit, and sit 1 inch lower then the back does now while he's at it.
Gonna look slammed on that big tire, and it should leave alot better, lower the front down some more too, get the car nice and low (they don't stand up as much that way) and then hit it with a 300 shot
Old Nov 5, 2008 | 12:17 PM
ndfrsd6's Avatar
make sure you take a lot of pic's ! that will look awesome
Old Nov 5, 2008 | 12:43 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Why not run the 28's + 4.56 + TH400? Might be a nice combo.
Old Nov 5, 2008 | 01:23 PM
ndfrsd6's Avatar
thats what im wondering ... with my t56 its perfect right at redline at the 1320. but would a th400 be the same gearing ?
Old Nov 5, 2008 | 01:40 PM
JL ws-6's Avatar
Race your car!
One thing that a couple old school racers have told me time and time again, run the biggest tire you can, and the highest gear ratio that you can... and the car will always hook good and leave hard.
If you already have a set of 28 inch tires mounted up that you can try first, I would do that before buying the 29.5's, and see where you're at.. but if you need to buy tires, I'd fit the biggest ones you fit, get them on there right away and go from there.
Old Nov 5, 2008 | 01:52 PM
ndfrsd6's Avatar
well said i've heard that before ..... thanks for your help
