Drag Racing Tech
What plug wires to use when relocating coils??
Old Nov 6, 2008 | 07:09 AM
JRracing's Avatar
Default What plug wires to use when relocating coils??
I'm moving the coils to the cowl panel and I'm not sure what custom set of wires will fit.
I want the MSD super conductor 8.5mm wires, but the boots are for a distributor.
How do you guys make this work??????
Old Nov 6, 2008 | 08:00 AM
Fireball's Avatar
you have 3 msd options:
MSD makes a universal cut-to-fit LS1 wire set with straight plug ends 32039
I did the LT1 wire set (LT1 opti connector is the same as the LS1 coil), but I needed 90* plug ends for my application (forcing me to use a LT1 wire set) so I used 32139
you can also get the LT1 wires with straight connectors at the coil (with a 90* plug end) 32139.
it all depends on how you want to route the wires...
http://www.msdignition.com/pdf_catal...og_132-147.pdf
Old Nov 6, 2008 | 05:10 PM
JRracing's Avatar
Thanks, that's what I was looking for. I like the option of having both.
Old Nov 6, 2008 | 07:38 PM
Gimp98TNT's Avatar
Moroso has a "Ultra 40" LS1 cut to fit set with the right boots. Havent used them yet. You can really use almost any EMI suppressed wire, but you'll have to get a set of LT1 coil boots, taylor makes them.
Old Nov 6, 2008 | 08:18 PM
Magnet's Avatar
This sponsor makes them,and sells them CHEAP. I got new wires and a full set of NGK plugs for $66 shipped!
Old Nov 6, 2008 | 11:03 PM
JRracing's Avatar
The MSD site shows a LS1/LS6 set that is universal with both a 90 degree and OEM style boot. It say's perfect for relocating the coils.
I just looked through my jegs book and they don't list that set. Is it that they just can not list every wire set MSD makes???
I'm putting them on the list and will call to see if they can get them for me.
Old Nov 6, 2008 | 11:08 PM
Magnet's Avatar
Sorry forgot the link click HERE
Great sponsor... and makes them for coil relocations as well
Old Nov 7, 2008 | 12:46 AM
JRracing's Avatar
Thanks!
Old Jun 26, 2014 | 03:41 AM
camarozz383's Avatar
Default wires
what sponsor? thanks
Old Jun 26, 2014 | 08:09 AM
RENE'S RAGE's Avatar
FireCore50
Call Rick Gorski @ FireCore
866-973-9473
He will make you a custom set.
Top of the line!
