Who's running Weld Pro Stars on 4th Gen Trans Am
#69
Thanks. I wished I could run a rear tire as big as yours. Right now I have 3.73 gears but I plan on buying a Moser 12 bolt soon with 4.11's. I like how your car looks with that much rubber under it. Any problems with rubbing? Is your car lowered?
#70
I also used to run a weld, but the drag lites. 15x10 with 7.5" BS and 15x3.5 with 1.75 BS. I ran the MT Sportman Front 26x7.50x15 8 ply. The rear, I used both a 325/50-15 MT DR and a ET Drag 28/10.5-15W.
Pic with the 28/10.5-15W
![](http://pic18.picturetrail.com/VOL915/3221468/6580279/343252564.jpg)
Pic with the 325/50-15
![](http://pic18.picturetrail.com/VOL915/3221468/6580279/249280234.jpg)
#71
Asside from the 1573's we've been mentioning. You may want to reconsider everything at this point. Since you do not have a new rear-end yet, there's quite a bit to consider. You're in a position right now, where I may even be able to help you with our Bogart wheels and setting up a rear-end and costing around the same as you're probably spending on your near rear with welds. In the end, you'll have a much better lighter setup all around.
Give me a call or e-mail me with my link provided below. Also include your full shipping address and I'll create a quote for you.
If you've already purchased the wheels...then there's no turning back unless you haven't mounted them.
#72
#74
I'm actually going to be running the Billet Specialty wheels now in a narrowed rear and much lower stance than those pics. I will be running the 275/60-15R tire now as well, to compete in the 275 DR class.
If you are really going to do a new rear, I would call SJM and see what he can do for you. It would be preferrable to get a narrowed rear and a nice deeper dish wheel in there (looks so much better) and sounds like he has a plan to do some sort of package for you like that, just food for thought. You can always sell those rims you bought if thats the route your going to take.
#75
BTW, here is how I got my wheels to fit with no caliper grinding, thanks SJM:
![](http://pic18.picturetrail.com/VOL915/3221468/6580279/343252562.jpg)
Heres the cut off bump stop I had to do:
![](http://pic18.picturetrail.com/VOL915/3221468/6580279/343252581.jpg)
and heres the area in the front I had to beat the crap out of:
![](http://pic18.picturetrail.com/VOL915/3221468/6580279/343252571.jpg)
Probably won't need to do any of that cutting of hammering with a 275 in there, just caliper grinding on stock calipers to get the rim to fit.
