Racing on 4 wheel studs
My best advice is to just fix it. If your on ARP studs, obviously you are much better off then running the crap stockers. If you on the stocker, you just asking for disaster. It only takes a couple hours at the most to pull the axle's and replace a wheel stud. Upgrade to ARP's while you have it apart. And never worry about them again.
Here is what you need:
ARP 12mm 1.5 knurl studs--two sets of 5 $25 total
Rearend lube, GM Additive,Black Silicone and a local machine or speed shop should be able to press them on.
Or take it to Midas, Mieneke, or any full service chain repair shop. Cost you about $200 plus parts to properly fix it if you dont want to pull the axles yourself.
Just need to be smarter than the average bear
