Drag Racing Tech
lt-1 in the 9's ????'s
Old Dec 9, 2008 | 06:04 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Originally Posted by 9sec93
no, it was a green turbo-charged trans am.
I was thinking of a car featured in GMHTP, it was dark, unfortunately I do not have the issue anymore. My buddy does, ill have to go over it.
Sad to say, thats kinda slow for a boosted car. Compared to the LSX stuff that LMR is running.
Old Dec 9, 2008 | 11:51 AM
Speed Density's Avatar
hashtagBMW
Originally Posted by Dave J
yeah thats Dave Diluca`s old car it went 9.11 back in I think 2002ish on a 400 shot(went mid 11`s on motor if I remember right)
it was the fastest LT1 car back then
since then tech has gotten alot better hell Joe Overton even went 9.34 on ALL MOTOR
Daves car went mid 10.80's on motor.
Old Dec 9, 2008 | 02:16 PM
BKHAWK1's Avatar
if it only went 9:11, we are knocking on that with a lot less dope!!! and i mean alot less dope... we have not even used the second kit.
Old Dec 9, 2008 | 09:28 PM
gator's 99TA's Avatar
my dad's car went 9.82 @ 140 1.50 60' on its one and only shakedown run in his 3700 lbs 95 Camaro LT1. Allen Futral tuned and made that pass. that was forever ago and he (dad) isnt into the drag racing scene. Its a garage queen. plenty of LT1 cars that go fast.
Old Dec 10, 2008 | 01:35 AM
Dave J's Avatar
I saw it run many 11 second passes on motor(never saw a 10)
but anyways I was not trying to put his old car down I was mainly trying to point out how much it loved the juice
Old Jun 20, 2009 | 02:53 AM
A20SVT00's Avatar
keep us updated 9sec lt1
Old Jun 20, 2009 | 07:34 AM
z28rob18's Avatar
im workin on this. 385ci lt1 220cc tea heads lt4 intake 200 shot 9" and a 6speed. and the ppl sayin its not cheap are right. im in 15k. i hav the individual coil per cylinder for it. the car should run the #s if i can drive it. so it'll take some time.
Old Jun 20, 2009 | 12:24 PM
AChotrod's Avatar
There is a LTx that will hit 7s this year. Its Z8s car. He was the first LTx in the 8s and will be the first in the 7s this year.
Plenty of fast LT1 cars and more and more popping up again. I also know of a mid 10 sec NA 350 LT1s running stock intake,TB, heads with 3angle valve job only.(stock eliminator car) Search Gizmo.
Or check out LS1Speed aka Larry from Speedincs LTX running mid 10s NA. Hell Im pushing 425ish RWHP NA on a bone stock shortblock, stock ported heads, stock ported intake and a custom cam with a S60 rear end.
LT1s are plenty capable of going fast.
Old Jun 20, 2009 | 03:43 PM
buzz12586's Avatar
Yea Larry from LS1Speed is going mid 10's NA and should easily be able to spray it into the 9's. Its still hydraulic roller I believe, drag radials, mufflers, very streetable, 3.73 gears. It just takes a well thought out setup. You can't just throw parts at it and expect it to be fast.
Old Jun 21, 2009 | 12:33 PM
nick97ta's Avatar
I'm building a 97 T/A with a 383, 210AFR's and a 91mm. Should be a fast car and my old setup was a ported stock head 383 and some spray, it went 6.79 in the 1/8. That was with A/C and everything on the car.
Old Jun 21, 2009 | 01:04 PM
FASTFATBOY's Avatar
You can do it.
383 4 bolt block
AFR,TFS or Dart heads
Solid or big hyd roller
Single plane intake with a plate system
Get some weight out of the car
turbo 400 with a brake
200 shot should go mid 9's, I know mine would even at 3600 lbs.
Larry at LS1 speed's car is pretty light, the more weight the more power you need, The more weight the more tire you need.
Old Jun 21, 2009 | 03:21 PM
  #32
AChotrod's Avatar
Fastfatboys car is another great example!
Old Jun 22, 2009 | 09:36 AM
  #33
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Dave Diluca's old car is now blue I think.
Big Rick's old TA went low 8's a number of years ago, and Z8's old YSi blower setup went 8.9's a few years ago as well. I think only Z8's car is still together, so his new twin turbo setup should go 7's.
Old Jun 22, 2009 | 11:53 AM
  #34
94 guy's Avatar
i have a LT1 396 motor complete with a accufab 4500 tb i'm lokking to sell cheap. the motor with old lt4 heads went 10.40 now the mootor has more comp. and a bada$$ set of heads on it. should easily run in the 9's
