Drag Racing Tech
lt-1 in the 9's ????'s
Old Dec 2, 2008 | 06:11 PM
gyellow's Avatar
Default lt-1 in the 9's ????'s
looking at purchasing an lt-1 roller for a street/strip project... looking for something running mid-low 9's consistently on a decent nx shot and high-mid 10's on motor... i was thinking of trying to keep it stock cubes with a turbo 400 and a 12 bolt. what would be my best motor options for the lt-1?? i have had multiple ls-1's and know nothing about the lt-1 so much help is needed!! i was looking at the lt-4 conversion but dont know if the rated 425hp conversion would be enough to get me to 10's on motor. anyone have good advice??? Thanks for the help in advance
Gregg
Old Dec 2, 2008 | 11:37 PM
Dave J's Avatar
Gregg
Maybe a AI heads and cammed 383 will get you in the 10`s but I am not sure how good that cam would be with a big shot of N2O
btw you will need about 600 fwhp to get to mid 10`s with a th400 and 12 bolt
forget the LT4 comversion you wil be lucky to get 11`s with it with a th400 and 12 bolt(25% drivetrain power loss)
Old Dec 3, 2008 | 06:28 AM
BlackScreaminMachine's Avatar
Internet Mechanic
Yea LT1's just need more mods to be as fast as a LSX equivlent. Thats why I moved on. Your talking biggest cubes that run reliabily. I would say is 396, but there has been motors that have done better, they are just not that common.
Your talking a direct port type system for anything over 150, its call gutting the car to an inch of it's life and putting all the safety **** in there and make sure it can run the # when you for NHRA lic passes.
It's not un heard of, just uncommon becuase you spend more $$$ per tenth then you do on LSX.
Old Dec 3, 2008 | 07:19 AM
Fast_94_Z's Avatar
put a big block in the car lol.
Old Dec 3, 2008 | 09:03 AM
gyellow's Avatar
ya i know its a lot easier with an ls..... how do they respond to different types of fi?? turbo or superchager??? or a big block?? not a bad idea i got a big block sitting at home anyhow
Old Dec 3, 2008 | 09:41 AM
BLKHAWK1's Avatar
My 355 lt1 with some home ported heads cc306 cam street tune th400 9 in went 11.90's N/A And I had a plate system that I hit with 300 and never had a problem that ran for three years like that. LT4 stuff is a waste I agree, look into Advanced induction talk to phil. I think you were talking solid roller cam? the downfall is the pcm wont support the engine speed past 7000rpm unless you have a 96-97 car and then the value you enter @7000 is the value for any speed after that point.
Old Dec 3, 2008 | 09:51 AM
Dave J's Avatar
I think if you want to build a low 9 second car a carb bigblock is cheaper and way more reliable at that level
I think with the LT-1 high 10`s are easy but anymore than that gets very expensive
Old Dec 3, 2008 | 09:53 AM
Internet Mechanic
Yup I am aware of that, another down fall of the LT1. The RPM limitation. Running 11.90's is one thing but for him to smash that barrier its going to take work.
For a 300 shot I do question the distribution capabilities of the dog house of the intake, #1 cyl is the ones that often gets starved.
If I was making a purpous built race car I would also look for a aftermarket engine management and convert the car to coil per cyl and use the opti as a pick up for the trigger or just have a magnetic pickup for the crank.
Old Dec 3, 2008 | 10:42 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
If the car is a roller I would do an LSx setup or BBC. LT1 strokers ain't cheap either.
Old Dec 3, 2008 | 10:45 AM
Internet Mechanic
Agreed, I thought I paid alot for mine in 2003 when I did a nu-tek motor, when I sold it, people thought that was damn cheap for the good parts inside of it.
Old Dec 3, 2008 | 11:16 AM
9sec93's Avatar
i think going mid-low 9's on stock cubes is possible. you will need a light car with good suspension. i went mid 10's in an LT1 car with only a cc503 cam, 150 shot, and bolt-ons.
Old Dec 3, 2008 | 11:20 AM
BLKHAWK1's Avatar
X2 I built a 6.0 l92 headed and ditched the lt1 way cheaper and way more bang for the buck. BTW distribution wasn't a problemlol I wouldn't switch to a mag pick up the opti is the best dist. ever you just need to keep it dry, its a laser pick-up you don't really get better than that. 396 high comp. hyd roller, light car good chassis and spray the **** out of it lol
Old Dec 3, 2008 | 04:26 PM
gyellow's Avatar
how hard would it be to throw a bbc in there?? motor mount and height wise and all that stuff??? i would b more happy throwing a bbc with a turbo 400 in there!!!
Old Dec 3, 2008 | 06:33 PM
JUICED96Z's Avatar
BBC
Check out the SBC/BBC section for info.
Most of the LT1 guys have moved on.... a few still around but not many... 9's is pretty easy but past that you run into issues. Fastest ever was high 8's if I remember right.
Old Dec 4, 2008 | 06:24 AM
9sec93's Avatar
Rick Intrau (Big Rick) went 8.08 with a set-up that wasn't anything crazy.
Old Dec 4, 2008 | 07:23 AM
BKHAWK1's Avatar
We went a low 9 last weekend on a 150 shot in a LT1 car. I am not sure what the cubic inches are in this car. My friend bought this car turn key. It used to hold the record for fastest LT1. A guy out of Canada built it. He has since passed away, but he built this car right. 14:1 compression, crank trigger and distributor, 9" and a glide. ITS NICE.
Old Dec 4, 2008 | 08:04 AM
Internet Mechanic
If that was the supercharged convertible LT1, I dont think he owns it anymore. If this is the guy I am thinking about, he was doing some shady **** and isnt around anymore. But that was a long time ago, if anyone wants to clarify, they are more then welcome to.
Old Dec 4, 2008 | 10:20 AM
Dave J's Avatar
yeah thats Dave Diluca`s old car it went 9.11 back in I think 2002ish on a 400 shot(went mid 11`s on motor if I remember right)
it was the fastest LT1 car back then
since then tech has gotten alot better hell Joe Overton even went 9.34 on ALL MOTOR
Old Dec 4, 2008 | 01:21 PM
ulakovic22's Avatar
Not hard at all, a handful of people have actually done it, I'm trying to wire mine up right now.
Old Dec 9, 2008 | 04:02 AM
9sec93's Avatar
no, it was a green turbo-charged trans am.
