project gutting wire harness, have questions
#61
Just got my chassis harness done. I used AllDATA PRO to go through the harness and it was nice, although very time consuming and frustrating im glad i did it. i like simplicity, the less wires the better and cleaner.
Sorry forgot to weight it, Guessing 4-5lbs
![](https://ls1tech.com/forums/attachments/drag-racing-tech/160749d1231750858-project-gutting-wire-harness-have-questions-cimg1742.jpg)
![](https://ls1tech.com/forums/attachments/drag-racing-tech/160750d1231750858-project-gutting-wire-harness-have-questions-cimg1741.jpg)
#62
hey man, thanx for that link. that could help alot of us out doing this mod. may consider that to simplify wiring and not to mention the cheap price compared to other kits
#64
No i am now going with manual windows. im just tired of replacing window motors. no matter GM replacement or parts store motors will hold up.
ill be running a gutted manual door with wolfe race craft door panels
Shooting for 2500lbs
#65
Could you list the circuits that you are now using.
#68
Its a 4th gen LS A4. before i took it apart this winter for the major overhall i was 3010lbs + 150 lbs for myself on top of that. so 3150lbs race weight
I now Have installed....
Sunuco Pin on hood,Pin on hatch/ lexan, wolfe mini tub and cut the whole rear floor and replaced with 18g steel
UMI Stage 6/FBX kit and full UMI rear suspesion
Tubular nose, frame horns forward
Drag wheels compared to the old heavy 18's
heater/ ac delete.
All interior brackets and miscelanios stuff are removed, ebrake cables/handle ect
Midwest chass 9'' soon - Eric said it will be lighter than my stock 10bolt when we get done with it
And thats about it that i can think of as far as weight reduction im doing
Taubr Unit
yes i figured they would be lighter than cranks. thanks for the info. I just would prefer the cranks because its no wiring in the door, less wiring in the chassis harness, and combined with the wolfe door skins it just doesnt get much simpler than that. ( except a vfn drag door lol)
abrower78
"Could you list the circuits that you are now using"
I will try to get some pics up tonight on the chassis harness and stuff that i pulled pins on
#69
this is a diagram of the chassis harness fuse block on my car 1998. not sure if they changed much in the fuse block between years but i can post different years if you guys want them.
U have to be car full though cuz gm harness tie alot of grounds and powers together through out the harness. for instance 4 of the fuses power wires might be coming from one (+ or - source). so if u pull the air bag pin power out and it leads to a " junction Block" where wires gather to one source of power or ground. THen just cut the air bag power wire at the juction so u dont cut the power off to the other possible needed fuse powers. just take you time and trace every thing out twice before cutting.
these are wut i deleted out of my car.... see pics
![](https://ls1tech.com/forums/attachments/drag-racing-tech/160802d1231801778-project-gutting-wire-harness-have-questions-78902084.gif)
![](https://ls1tech.com/forums/attachments/drag-racing-tech/160801d1231801778-project-gutting-wire-harness-have-questions-78902085.gif)
IF U CANT READ TRY TO ZOOM IN > SHOULD HAVE A ZOOM AT BOTTOM RIGHT CORNER OF WEB BROWSER, OR TRY VIEW > OPTIONS TOP LEFT
#71
Question for you guys who have done this. Is it worth going through the harness or is it better to just tear it all out and rewire it?
Reason I ask is I'm loosing the computer completley and going to a carb setup.
I need to keep all the lights for street driving but thats it.
Thanks,
~Jim~
Thanks,
~Jim~
#73
Thanks,
~Jim~
Thanks,
~Jim~
#75
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
#76
If you're doing it for weight, there are better things you can unbolt/cut out.
Save the harness as a last resort. The bulk of the wiring is really the stereo system.
I did it because I wanted to clean up the car. Tedious and time consuming but a fun project.
#77
yup, monsoon wiring=ALOT
#80
is really easy for me tho, a/c heat, ducting, dash brace and firewall insulation are all removed
