Electric solenoid for Cheetah shifter?
I figure I can make any solenoid work, I'll just make a bracket. I do need an rpm switch though, and recommendations?
Also, having never used one of those solenoids before, how do they work? It looks like they default to an open position. Do you just "****" it back and let the rpm switch release it?
I bought an air shifter from a swap meet for $20 and the used a MSD digital window switch to activate it. I just had to alter the bracket to work with my quarter stick, but $20 in a CO2 shifter setup that I can run on air or gas isn't a bad deal...
Then you have the shiftnoid style that when you apply power it bumps the sifter, those work as well but they take a pretty good ampunt of power to work right, at least a 10ga wire straight to the battery and they are limited on pushing power.
The ACD is complete though and does all 3 gears with a different RPM setting for the 1-2 and 2-3. I'm pretty sure the box will work with an LS,like any other window switch/shiftlight/tach it needs to be set up for a 4cyl.
Thing with electric/air shifters is you want it to work every time, I have used the ACD setup on a cheetah and on a prostick and if you turned on the Co2 bottle they work, hot or cold, cable binding a little, didnt matter. But you can certainly piece something together for the 1-2 shift on your own for next to nothing.
i have a hummer shifter(forword),would ACD work for me?
i asked about the electrical shifter a couple weeks ago but got no clear answer of what they are using!
i didn't use any kind of selenoid till now,,,but after reading what Kp said i think i'll go with the Air shifter,i don't want to misup shifting in the race,,i got alot of low 9's and high 8's car in my N/A class
