Drag Racing Tech
Trans Am guys with Shift Lights?
Old Feb 17, 2009 | 02:27 AM
  #41
chvypwr31's Avatar
on the topic of shift lights i have an autometer pro shift light for sale and ill give you a set of pills to go with it i believe there 6k-7k. heres the link to the shift light. http://www.jegs.com/p/Auto+Meter/745859/10002/-1. message me seperately if interested, i dont want to hijack thread. and i had mine mounted in the vent itself, the one right next to the door.
Old Mar 3, 2009 | 08:25 PM
  #42
Sideways240sx's Avatar
ok.. so this is what i had in mind. I just did it. Not in the car yet.
Took a couple minutes to do
Chris
Old Sep 20, 2009 | 07:17 PM
  #43
MetallicaMatt's Avatar
wow... 6 months later I finally installed this damned thing lol
but it wont work!
tach wire to #10 pin, white wire on the pcm (red)
12v keyed
ground, easy
it lights up, blinks the settings back, but wont come on at the rpms, i've tried several rpms, mainly 1000, 1500 etc
yes it was in 4 cylinder mode....and nothing
checked the voltage at the connection at the pcm (which is sodered) and got 0.030VDC (or close, can't remember)
same voltage all the way up to the shift light, but nothing is working??
Can't get hold of Harlan, so what do I do? can I tap into something else and then use a different setting?
