Drag Racing Tech
my weight reduction list
Old Dec 18, 2008 | 11:37 PM
blockheadnic's Avatar
Default my weight reduction list
Starting my winter project. iam removing weight to start with.
So far ive removed,or plan to remove.
Front sway bar, and brackets.
Front and rear bumper supports.
Cruise control.
All the plastic pieces up front.
wipers,arm,motor,jug.
abs module.
a/c stuff, hvac box.
carpet padding.
rear seat, and belts.
pass,and driver seat replaced with kirkey seats.
fog,turn and high beam lights.
rear speakers.
is there any other things that i could remove that would be worth taken out.
Old Dec 19, 2008 | 01:12 AM
BlackWS666's Avatar
Door bars. 7.5 pounds a piece, that's all i can think of for free stuff. Its a noticeable difference when you open, and close the door.
Old Dec 19, 2008 | 01:15 AM
Driftunit's Avatar
what plastic stuff up front because im sort of doing the same thing
Old Dec 19, 2008 | 01:17 AM
Driftunit's Avatar
also! how bad does removing the front sway effect handling? if you dont mind me asking
Old Dec 19, 2008 | 01:27 AM
the_merv's Avatar
Veteran: Air Force
It will make it roll a little more in the front..
Old Dec 19, 2008 | 02:06 AM
letsrunem's Avatar
If you like corners at all don't do it. I take mine off just for the track, it can be kinda scary in some situations.
Old Dec 19, 2008 | 09:40 AM
Dragkid1917's Avatar
My experience with my swaybar off was one close call going 80 mph, locking up the breaks, having the car float all over the highway, spinning out, then smashing into a concrete wall. Oh and without bumper supports there either, your car doesnt stand a chance. The insurance company dicks you over as well.
I personally didnt even notice the difference, untill I needed the stability in an emergency, and it wasnt there. Now I will take off the swaybar only at the track.
Old Dec 19, 2008 | 09:48 AM
w3s1c0a5t's Avatar
Horrible it worked out that way bro. But I have had a car pull out on the highway with me well doin XXX and i had to slam on the breaks and felt like i had control the whole time. Didnt have to steer much but i did notice the nose dive more.
Old Dec 19, 2008 | 10:35 AM
chrs1313's Avatar
heat sheilding is worth another...~8lbs
emergency brakes and cables...~8lbs
rear well rubber matting under carpet...~2lbs
lightweight battery...~15lbs
visors...~2lbs
side morrors...?lbs help aero too
spool in the rear...~15-20lbs (if track only)
etc...
Old Dec 19, 2008 | 10:42 AM
TA1364's Avatar
Antena motor lol
I dont have my front sway bar on and cant really tell any difference.
Old Dec 19, 2008 | 11:24 AM
Same here i pulled it and barely noticed it. i did it on my old t-bird, because i refused to buy new end links that car defently needed one.
Sam you got any goodys for sale besides the TC.
Driftunit, i removed the plastic inside wheel well that was 5lbs.
And all the plastic under the front bumper it was worth maybe 10 or so pounds. plus all those damn screws and pushpins.
I dont want to remove the crash bars just yet i couldnt live with myself if i got t-boned and it hurt my passenger.
i want my car at a glance to look stock so some things i want to keep.
Does anyone know how much the HVAC box and head unit weigh?
Old Dec 19, 2008 | 11:49 AM
BlackScreaminMachine's Avatar
Internet Mechanic
You can def tell there is a different with the front bar out, dont let ANYONE tell you otherwise, it is just that people got used to it being out. I am one of those people.
Supposedly MightMouse put a Rear Drag Bar by TRZ that stiffens the car up so much it makes driveability more like stock since it isnt letting the car roll at all.
Old Dec 19, 2008 | 01:36 PM
STANG KILLA SS 2's Avatar
sway bar removal on the street is big difference. doing 30 and yanking the wheel left to right is fun. so much body roll the car goes straight and the body just humps the road left to right.
but i also when from 18" with lopros to 16" with slicks so sidewall had allittle to make it worse too.
Old Dec 19, 2008 | 01:41 PM
Driftunit's Avatar
i think ill just leave my bar in because i love the curves. PLUS! i live in the mountains of north carolina and i dont think we have a straight road here lol.
and as for the plastic stuff you removed, i always heard that the pieces that connect to the front bumper have a lot to do with aerodynamics and help air flow that goes under the car. so at high speed you could be hurting yourself more than helping
Old Dec 19, 2008 | 02:20 PM
TA1364's Avatar
Honestly unless someone is willing to come take the parts off the car I am going sell it as is. I am leaving the week of jan. 12th.
Old Dec 19, 2008 | 03:10 PM
Well i dont drive my car like a nascar so i never really felt it to much, i drive my car on the street like a grandma.
Maybe when i remove enough weight from the front it will be even worse.
Old Dec 19, 2008 | 05:31 PM
Ed Wright's Avatar
9-Second Club
Yours are heavier than mine were, both of mine were MAYBE 7 lbs, including the bolts. Almost more trouble than it was worth.
Old Dec 19, 2008 | 07:03 PM
Yeah i think i will wait till i put a cage in mine, for that one.
Old Dec 21, 2008 | 12:54 PM
Chris05ssTruck's Avatar
I've never had any problems w/ the sway bar being gone, u notice a difference the 1st corner, after that it feels normal.
Old Dec 21, 2008 | 01:26 PM
slowandrichws6's Avatar
does the sway bar gone make a big difference at the track though????
