Drag Racing Tech
Lightweight carpet
Old Feb 25, 2009 | 01:33 PM
  #81
ndfrsd6's Avatar
thank you ! i just took my time ....the shifter is a b&m ratchet i have the alum case on order ..
Old Feb 25, 2009 | 01:53 PM
  #82
Cobra Commander's Avatar
Originally Posted by kp
OK, I see what they did, they shorter carpet that ben Arthur has doesnt have the rubber backing like the full length carpet that I bought.
Thats a huge weight difference since the full set I have with the rubber backing was over 40lbs out of the box. I guess I'll order the shorter version, cant beat losing 20lbs for 140.00..
I was confused on this so I called. They said the full length carpet was 16 lbs. Can anyone else confirm this?
Old Feb 25, 2009 | 01:54 PM
  #83
ndfrsd6's Avatar
here is a better pic
https://www.hallspeedshop.com/images/bm/80842.jpg
Old Feb 25, 2009 | 01:55 PM
  #84
ndfrsd6's Avatar
the one i got was the shorter version but has no rubber backing ....in the box it was 13 lbs
Old Feb 25, 2009 | 08:35 PM
  #85
kp's Avatar
kp
Its possible, but I talked to ACC directly (the people who make the carpet) and they said they will not sell the full length F-body without the rubber backing any more but the convertible carpet (the shorter one) they do.
Maybe speedinc is getting it from another carpet company now or ACC started selling it again w/o the rubber backing.
Old Feb 26, 2009 | 05:01 AM
  #86
358chevycamaro's Avatar
Originally Posted by ndfrsd6
sorry it took longer to get the pics up ...but i think it looks ok
So this is the Speed Inc. carpet correct??
Could you fill in all the details please? I never saw the answer...
-What version is this?
-Did you weigh it? If so whats it weight?
-How much was it?
Old Feb 26, 2009 | 07:35 AM
  #87
ndfrsd6's Avatar
i was 13 lbs in the box so with trimming you remove a 1lb so about 11 lbs when done ....it is the shorter version , i got some carpet from home depot for the trunk area ....
http://www.speedinc.com/catagory.cfm...r%20/%20Safety
Old Feb 26, 2009 | 04:35 PM
  #88
InsaneAuto86's Avatar
I was thinking about using truck bed liner (Line-X, Rhino-Lining) on the inside of my camaro. I hate seeing wrinkles in my carpet and dont want to glue it down...
 Michael S. Palmer
Old Mar 6, 2009 | 02:47 PM
  #89
STANG KILLA SS 2's Avatar
i was contimplating this too. DIY roll on bed liner. maybe even just the front seat area.
anyone done this?
also the only carpet i see on speed inc is GM replacement carpet...
http://www.speedinc.com/cont.cfm?cid=C0000831
Old Mar 6, 2009 | 03:13 PM
  #90
anyone done this?
A thin layer would be light and easy to clean...
Old Mar 6, 2009 | 03:36 PM
  #91
my thoughts exactly, and it would fit great and no trimming!
maybe even throw a couple floor mats in for street driving i dont think youd hardly even notice.
Old Mar 6, 2009 | 03:48 PM
  #92
ndfrsd6's Avatar
anyone done this?
that is what i got .....it was 13lbs in the box im not a big fan of the bedliner stuff
Old Mar 6, 2009 | 03:55 PM
  #93
thats the exact part number you bought? at 12-13 lbs that seems to be best route.
you bought the full length one right, with rear hatch area
did you weight your stock?
Old Mar 6, 2009 | 04:43 PM
  #94
ndfrsd6's Avatar
i bought the short version .....i did not weigh the stock but i know its like 48 lbs give or take
Old Mar 6, 2009 | 05:00 PM
  #95
ItsNotStock's Avatar
I bought the stockinteriors.com carpet and it definitely weighs more than 13 lbs. I'm thinking I should have went with SpeedInc instead.
Old Mar 6, 2009 | 07:50 PM
  #96
94 guy's Avatar
what about the Trim parts carpet and ACC summit sells both.
Old Mar 6, 2009 | 07:54 PM
  #97
RaggedRides's Avatar
I want to see pictures of examples where fellows are using the rolls of parts store carpet. Where ya at?
Old Mar 10, 2009 | 03:36 PM
  #98
southerntp's Avatar
Originally Posted by 02 BLK WS6
3 rolls of Ozite and a couple bottles of spray glue did the trick for me. My stock carpet weighed more than 35 lbs, I'll have to verify as it felt more like 50+ when I removed it.
Where have you guys been able to find the ozite carpet at? I have been looking and I dont know where I can find it at? Also around how much would it cost for glue and everything? I need to get this stuff ordered as soon as possible. thanks in advance.
Old Mar 10, 2009 | 04:05 PM
  #99
94 guy's Avatar
who makes the speedinc carpet?
Old Mar 10, 2009 | 05:40 PM
  #100
SpeedInc carpet is less than 13lbs. The box weights 13lbs and I still cut a LOT of carpet off to fit it in.
