4150 tb/105mm and vic jr/super vic, questions
Okay, i've tried to find information that would be helpful to me but I haven't found exactly what I want and now the search feature doesn't seem to be working so i'll just ask.
I currently have a vic jr/accufab 105mm tb with a fabbed elbow. I want to know if i'm leaving anything on the table with regards to using a 4150 style 4-hole tb vs my current elbow mounted 105mm. Also, was thinking about moving to the super vic as my car is pretty much a drag car. Has anyone seen differences between these two?
I would still use my custom 4" tubing coming from the front of my car to whichever tb would be best for my situation.
Please, if someone has info or thoughts on the subject, I would appreciate the feedback, thanks,
-=Josh=-
-=Josh=-
Dude thats a bad *** setup! How did you get a 4 inch pipe down there in front of the radiator?
There was a recent thread here about the same thing, guy with a truck picked up around 60 rwhp on a 408 when he went from an elbow to a 4150.
Yeh, go to the dyno section and look around. There is a post of a guy with a 408 in a truck that picked up 60 rwhp with this swap.
You can do a 4150 style 4 hole and put a carb hat on it and use your tubing like you have now.
I believe you will pick up some hp with a 4150. I am debating the swap myself.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![](http://i188.photobucket.com/albums/z1/vega406/Camaro/air1.jpg)
![](http://i188.photobucket.com/albums/z1/vega406/Camaro/air2.jpg)
![](http://i188.photobucket.com/albums/z1/vega406/Camaro/aftb.jpg)
Also, after checking Accufabs site, it looks like my current 105mm out flows the 4150 style one (i'm not sure where they rate the 4150 style at but they said something like 1215 cfm's where the 105mm was rated at CORR @ 20" - 1270, CORR @ 25" - 1422, CORR @ 28" - 1504)
More variables lol.
I currently have a victor jr intake. I was going to go with a elbow from intakeelbows.com and a NW 92mm TB but after some research and talking to a few people on here, from what I see, I will make more power with a carb style TB, so I bought a 4150 to 4500 2" adapter and a 4500 Dominator TB setup. No dyno numbers with this setup yet, but it should be tuned soon.
Race your car!
Another way to go about it, is go with Cary's intake and that's got a 4500 flange on it right off the bat, and will outflow the edlebrock single planes and the GM ones by about 50 hp, it's $ but still not at sheet metal prices, and it's making mroe bottom end then the sheet metal does, so it's a win win IMO
Yea, I saw that but I was looking for more positive feedback b/c I know this seems to be working well now. That truck also went from a 90mm (accufabs 90 flows CORR @ 28" - 1369 CFM) and went to a 4500 style (accufabs flows 2128), quite a bit of difference lol. I don't know if I want to run an adapter which will raise the tb even higher (about 2 inches).
More variables lol.
More variables lol.
I dont see you needing a 4500 setup. Call Accufab.
https://ls1tech.com/forums/dynamomet...-b-change.html
This guy went from 512rwhp with a elbow and 90mm to 562rwhp with a 4500 FAST TB.
