10 point is installed need cert.
Also the welder couldnt get to the underside of the rocker bar or the back side of the dash bar, Im thinking this is not good. Will this pass inspection? The bars welded to the plate are welded with a mig and the rest with a tig does it require to be fully tig welded?
Joe
If you have a local chassis shop they should be able to tell ya when they're next cert is.
If there's something that isn't welded all the way, that may be a problem. I'd try to get it welded all the say, and if you can't, put a small piece of tubing in the corner of that point to make a triangle at that point, then they won't give you too much trouble.
You don't want that coming apart in a crash that I'm sure of.
Joe
Joe
