10pt Wolfe RollCage Install w/pics
Seats and Carpet out:
Center Console out:
Start of Dash Removal:
More Dash Removal:
Steering Wheel & Dash Removed:
Dash out:
Steering Wheel Back on:
I tried starting the car and it seems like its in alarm mode, so i will be figuring out how to trick the car to run so I can take it to fargo to get my roll cage installed. I dont have an appointment yet but it should be soon.
-Grounds were never hooked back up, once they were for the Body Control Module it ran fine.
Rollcage Pictures
Rollcage fit pretty well, T-tops work just fine with plenty of room.
Swing out bars(had my installer put these in)
Removeable side bars
Using tagboard to keep the interior away from what I was doing.
Pictures of Painted Cage
Cutting part of air duct out for cage:
Before
After
Dash Bolted in(Radio & Vent Controls In):
So far as I know everything was installed, side bars were custom made removeable.
We supply a Drivers side rocker bar (sill bar) on all of our cages. It runs from the bottome of the main hoop (just above the floor) to the bottom of the side bar (bar that comes thru the dash). Depending on the car and how you read the rules it isn't necessarily required. We always supply one in our roll cage kits and always install it. Like the idea of having an additional bar under and to the outside of the driver as extra protection.
Install Looks good!
looks good.
does por 15 offer a satin finish?
im getting ready to do a cage, and the gloss is a bit much for my tates.
not to take away from yours. just personal preference.
Car completly gutted:
Cage being installed:
Another added the firewall bar and also added both lower rocker bars right/left sides:
Finished photos, also added a Alston swing out door bar:
Kirkey seats, window net, SpeedInc light weight carpet, Grant steering wheel:
Rear View:
looks good.
Next week the dash should be almost wrapped up, have to mount the BCM (body control module) with zip ties or something, the passenger side bar passes right through the old mount for the BCM.
