Steel VS Cromoly rollbar?
theres a reason I cut my MS cage out and am paying for CM - I regretted going with the MS.....weight is crucial. I'd sell the one you bought, and have Collin (I assume) fab you up a nice CM cage.
OR save the weight on the cage AND find "that extra weight" and take that out also and loose twice as much weight!!
People tell me that all the time "just take a big **** in the morning to loose that weight"... "ok, or i cut this out and do that and be even lighter!!"
Im going with CM 8pt... i wouldnt even think twice about it especially on a cage thats getting welded in. DO CM AND SLEEP BETTER AT NIGHT!!
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
Im going with CM 8pt... i wouldnt even think twice about it especially on a cage thats getting welded in. DO CM AND SLEEP BETTER AT NIGHT!!![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
LMAO, you know every year in the past right before race season, I used to go on a diet and lose a shitload of weight.... haha This year I got carried away im a fat-***.
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
I have a complete MS cage in my Nova and I know it's heavy but there's a big cost difference. I don't care about a tenth so I saved the $$$ in material and labor and put it towards something else. If you have the cash and want to keep the weight down, do Moly. If not, well you know!
Derek
Derek
Anytime you can save 1lb of weight for under $10 DO IT!!!!! A typical chromoly cage (6-8pt) will save you around 20-25lbs and only costs about $200 or so more. Think of how hard it would be for you to drop an additional 25lbs off of your car if it were already gutted and had skinnies/slicks.
To save 25lbs you could get a k-member and a-arms ---$750+
or................speedglass for the rear hatch------$399+ $90 shipping
or................manual steering rack--------------$500+
or................drag brakes for the rear-----------$450+
etc,etc...
Goind from DOM to chromoly is a very cheap way to lose weight.
etc,etc...
In this case, I've decided to have a CM built and I put the MS one up for sale.
#32
etc,etc...
etc,etc...
#33
Just to set things straight guys... From my understanding in engineering/chemistry classes as well as from my father who owns an engineering and design firm, Chromoly isn't actually lighter, however it is stronger so you can use a thinner metal for the same strength... Correct me if I'm wrong guys...
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#34
Just to set things straight guys... From my understanding in engineering/chemistry classes as well as from my father who owns an engineering and design firm, Chromoly isn't actually lighter, however it is stronger so you can use a thinner metal for the same strength... Correct me if I'm wrong guys... ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
#35
#37
thatis exactely right. The reason why cromoly is lighter is because its a thinner wall tubing, not because of the actual material.
![Nod](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_nod.gif)
#38
you still have to use the same diameter tube whether ms or moly. 1 3/4 for rollbar and 1 5/8 for rollcage. the difference is when using ms i think it has to be .118 or .120 wall where you can use .083 wall moly. it gets more complicated when you start getting into intricate cages. example, when using the x-style door bars, you can run smaller diameter tubing than the normally required 1 5/8 for just the single door bar.
#40
The point I was trying to make is that a typical 6-8 point cage will only run you near $200 more for chromoly, and you will not EVER find a way to replace ANY component on your car for that kind of money and save that kind of weight. It is the best money you could possibly spend on your car.
