stock suspension rules legality
The bars are going on it with the stock panhard bar and we're going to experiment with the travel limiters and adding weight up front. My fabricator is going to do us a weight box like he's seen on outlaw drag radial cars out in front of the core support.... If we have to add 50lbs to the nose we will.....
and of course i'll go out to the track with about 13psi in the tires pre burnout and start leaving on a 225 shot..... instead of dead hooking the 150.....
thanks to everyone that replied.. this has turned out to be a good tech thread...
"Cars don't squat, girls do."
Avoid nutswingers: for genuine Madman products, buy only from authorized dealers - http://madmanandcoracing.com/dealers.htm
Authorized dealer for AFCO, Mickey Thompson, and Strange Engineering
Now you've got the boss pissed!
How you doing Ruth?
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
there's some things I can do otherwise... i don't class race and it's pretty much a heads up car... I want to get it to leave crazy as **** but barely touch the wheelie bars.... with them out there i'll feel more comfortable trying new things.....
as an aside however the radial guys (a la Brady) have to dead hook that tire or they will go into UGLY tire spin as radials do not recover like slicks.....
so they aren't doing it with tire speed right???? I know madman would have to get on here and divulge how you get a wheelie bar less car to carry the tires 2" off the ground for 300+ feet without going up on the bumper....
Right, radial slicks (I can't say about ET Streets) need to just about dead hook. They do not recover worth a damn. I don't know about a seven second car, but a nine second car will keep the front end down with tight front limiters, front shocks slowed down and correct weight balance will keep the front end down. Mine would go from scraping the bumper to carrying them a couple inches off the ground by making simple those adjustents. Normally knock three to five hundredths off my et in the process. Great big wheel stands (at least mine) are usually an "oops!" You need to make provisions to enable you to move weight to the front of the car when needed if wheel stands are an issue. Especially if you run on several different race tracks.
I'd look into that, couple bars with holes so you can slide a bolt in and out at a couple different distances, so you can add more then one weight if needed.
