1SC stripper build
nice build BTW
Front bumper delete.
Fitted on car
Home brew ram air system in process. Waiting for correct duct to show up.
I wish I was as fast as you in getting done.
Should have the front back on and all buttoned up by next weekend.
Removed the fuel tank
Drilled .188" holes on the inside of the 4 corners of the tape and then used a Unibit to make a hole big so I could start cutting with my tin snipes to the inside edges of the tape.
Put door edge molding on the cut edges
I will fabricate a lid tomorrow
Used a M8 coupling nut.
http://www.mandhtires.com/store.php?...on=show_detail
Rear: M/H 275/50R17
Get a small tubing bender, it makes for easier forming in the small area if your engine is in the car.
Use this type of flaring tool if possible, perfect flare everytime.
