Drag Racing Tech
1SC stripper build
Old Jul 17, 2021 | 06:56 PM
  #381
gjohnsonws6's Avatar
Originally Posted by Heyfred
Getting ready for Chrome Moly roll bar install. The car has only 13,000 miles and the the roof is gassing badly, (paint bubbling) due to the adhesive used to glue it on in 2002. To make it easier for the roll bar install, the original roof will be removed and a new carbon fibre roof from Midwest Chassis will be installed once roll bar is completed.
What was the lead time for the roof ?
Old Jul 17, 2021 | 07:36 PM
  #382
Heyfred's Avatar
Ordered on 4/2 and shipped on 4/8.
Old Jul 24, 2021 | 12:37 PM
  #383
Heyfred's Avatar
Once once all fabrication is done, OEM Paint/Primer color used from the factory will be applied.
Old Aug 31, 2021 | 10:37 PM
  #384
Heyfred's Avatar
Holley Terminator X Max has arrived. The wait was worth it.
Engine dressed out and ready for the engine dyno. Once several small parts show up this week, will get scheduled
Took advantage of the holes and made some tabs to hold the wires in place.
Old Sep 12, 2021 | 05:58 PM
  #385
Heyfred's Avatar
I hope all bases are covered. Ready for the engine dyno. Heater delete bypass hoses, done, passenger side head temp sensor hole plugged, done, short belt conversion, done. .125” thick washer required behind pulley. Done and ready.
Old Sep 25, 2021 | 11:46 AM
  #386
Heyfred's Avatar
Roof is being replaced (13,000 miles on the car) due to the paint bubbling caused by the the OEM adhesive used in 2002 to attach the roof skin. Took 4hrs to get the skin off and the adhesive all removed from the metal. Then sealed with DP90. Heating a putty knife helped to get the adhesive off the metal, then use the synthetic wheel get what was left off the metal without removing metal.
Interior all out and headed off to the chassis shop for Chrome Moly roll bar (5pt, street car).
Having owned this car since 2008 and bought with 8,500 miles, it’s odd going out to the shop, not seeing or walking by it. This is only the 3rd time it hasn’t been at home in the shop. Excited to see the transformation.
Test fitting 4” exhaust.
Old Oct 1, 2021 | 01:52 AM
  #387
Heyfred's Avatar
Chrome Moly rollbar all done and will be back home soon. Robert at Radioactive Fab did an excellent job.
Old Oct 1, 2021 | 08:55 AM
  #388
I’ve never seen moly without a coating unless intentionally removed. Looks more like Docal
Old Oct 1, 2021 | 11:37 AM
  #389
Heyfred's Avatar
I supplied the the Chrome Moly material, Robert cleaned it before using. Docal tubing looks to be a good option.
Old Oct 4, 2021 | 05:50 PM
  #390
Heyfred's Avatar
The ole girl is back home. Off to the engine dyno and rewire the car, next.
Old Nov 23, 2021 | 05:27 PM
  #391
skidze01ss's Avatar
Great thread, thanks for taking the time to document your progress and share such detailed progress.
I do have a question though. Why are you getting rid of the built 4L60E? From your description you bought the best money could buy.
Old Nov 23, 2021 | 08:39 PM
  #392
Heyfred's Avatar
With the new engine hp and tire diameter change, I needed a different trans gear ratio. The 4l80e gives me more gear options.
I already upgraded the 4l60e with all the good parts and gear options. Works flawless, but only gives me one gear set option.
Old Nov 24, 2021 | 01:45 PM
  #393
skidze01ss's Avatar
Gotcha. Thanks for sharing that info, and for the thread. It's been a fun read.
