1SC stripper build
Here is some of the sheetmetal work getting done. The torque is difficult to adjust for pinion angle.
Thought I had some 20ga sheetmetal and it turned out being a sheet of aluminum. So, I did the next best thing.
Done for today. Have to buy a sheet of metal tomorrow.
Came up with some ways to eliminate some welding. Formed the floor pieces up as one.
Before:
After:
Removable tunnel:
Next will be tacking the floor panels into place,getting some duz fasterners and mounting the removable tunnel.
Then, remove the rearend and fabricate a 1" flange around the cutout above the rearend so the tunnel has something to seal against.
I have several picked out.
http://www.mickeythompsontires.com/i...pro_5_drag.jpg
http://weldracing.com/street-performance/rt-s-15.html
http://www.radirwheels.com/wheels.htm
I made a pattern to fit the removable driveline tunnel.
Calculated my flanges and and notched the radius because I can't bend a flange on it.
Flanges turned up.
Here is the formed part.
From the bottom of the car.
Need to decide on what fasteners to to use to hold the cover on, Duz or quickcert.
Keep up the good work!
Floor panels are welded in. Pictures from the bottom of the car.
Right side:
Decided to remove the rearend to make things easier.
Left side:
One more piece to go. Going to try and get finished up tonight.
and had to fix.Next , clean up, decide on fastener to hold cover on, paint and seam seal.
Decided to use Nutcerts to hold the cover on.
I cut out the bump stop mounts and while I was in there, I was looking at the fenderwells where alot of people have to clearance front inside of the fenderwell for tire clearance. Being in the cut and weld mode, I pulled out the sawzall and went to town.
First I decided how far forward to go. Looking into the fenderwell from the side, I sighted staight back to the inner fenderwell and determaned the starting point. Tire is not going to be any farther forward than that point.
I wanted to try and follow the contour of the inner fenderwell. Decided to start cutting and made a pattern that follwed a the contour I was looking for.
Looking from the back of the car:
Side
Cleaned the seam sealer from behind the areas to be welded. The brace on the inside of car is still in place. Just cut away the bottom flange in the area of the brace where the new piece of sheetmetal was going to be added.
Cleaned up the welded area and sprayed with some self etching primer. once the primer dried, applied a light coat of undercoat.
Just need to paint and seam seal to be complete.
Next, will be finishing the fenderwell modification to the right side.
I was not able to get the torque arm level with the bottom of the the car before the modification.
The front inner fenderwell modification for tire clearance.
