Drag Racing Tech
1SC stripper build
Old Dec 27, 2011 | 12:45 AM
  #201
1dirtyZ's Avatar
great progress man!!! you make it look too easy
you might want to cut or relocate the E-brake cable bracket in the tunnel , the torque arm will hit it as soon as you hit any bump. (are you even using the E-brake anymore?)
Old Dec 27, 2011 | 06:42 AM
  #202
Heyfred's Avatar
The ebrake is going away. Rearend is getting narrowed up 3.25" per side. One of the things on my list is to remove the ebrake cable going to the ebrake lever.
Old Dec 27, 2011 | 05:37 PM
  #203
LongIsland63SS409's Avatar
What rims/offset did you decide on?
Mike
Old Dec 28, 2011 | 12:40 AM
  #204
Heyfred's Avatar
The Weld RTS is currently at the top of my list.
http://weldracing.com/aitdownloadabl...itfile_id/309/
Weld RTS # 71MP-509B45A
15x9.33
5x4.75 BC
4.50 BS
Medium mounting pad
16.7 LBS.
Old Dec 28, 2011 | 07:01 PM
  #205
studderin's Avatar
thats looks great!
more info on thouse nutcetrs, and the gun? got any upclose pics?
How much do thouse bump stopes weight? I still have mine trimmed down . its like 3-4 layers of metal tho. Are you glad you cut them out, still think its strong?
Old Dec 29, 2011 | 12:32 AM
  #206
Heyfred's Avatar
2lbs each, including 2 bolts and rubber stop. Also rounded to make up for lost material from hole saw.
There is a 90 degree flange down, on the inside of the stock spring bucket, I cut right up to it. In my thinking, this will help keep the structural integerity of the sheetmetal supporting the rear frame rail.
Drivers side
Passenger
Old Dec 29, 2011 | 06:13 AM
  #207
15x9.33
5x4.75 BC
4.50 BS
Medium mounting pad
16.7 LBS.
Nice choice!
Love to see pics when you get them mounted up.
Mike
Old Dec 29, 2011 | 01:40 PM
  #208
Heyfred's Avatar
http://www.rivetsonline.com/39301-ki...with-tool.html
I borrowed one that was purchased through Snap-On.
This will give you an idea what is available.
http://www.jhpfasteners.com/rivet-nuts-c-43-l-en.html
Old Dec 29, 2011 | 03:51 PM
  #209
Heyfred's Avatar
Rear wheels ordered today.
Old Jan 3, 2012 | 10:07 PM
  #210
Heyfred's Avatar
Decided to remove the rear coilover and put the spring in the stock location. Spent some time over the holiday designing an in car ride height adjuster set-up and incorperated the roll bar pad area.
Time to cut and see what I find.
Right rear, inside car, over stock spring bucket area.
This area needed some structural help if I was going to incorperate it into the rollcage. I plated 3 sides. The area to the front of the car (shock area)appears to be 16 or 18 guage, should be strong enough.
Waiting for the jack bolts to get here so I can keep going.
Old Jan 5, 2012 | 12:58 AM
  #211
stangtrader's Avatar
looks like the cars coming along Keith,did you go with the black rts wheels or polished?
Old Jan 6, 2012 | 01:10 PM
  #212
Heyfred's Avatar
Last night, I needed to get something done, so I removed the ebrake handle and cable.
Purchased a 4" holesaw this morning and removed the stock upper spring locators.
Located a 10" spring for testing and built a temporary spring locator that bolts to the housing.
Installed the spring, raised the rearend till tension is on the spring and 90 degrees to the spring pad.
Looking up into the stock upper spring bucket, the coil spring is going to be positioned back from the stock location.
Old Jan 7, 2012 | 08:52 PM
  #213
wws699's Avatar
I believe a 12" spring would be better for drag racing
Edit:
Never mind 150lbs x10" 2.5"
Old Jan 7, 2012 | 09:01 PM
  #214
Heyfred's Avatar
The new 10" springs came in. Waiting for several parts to arrive to complete the project. The prep work is done and ready for welding once the rest of the parts arrive.
Made plates to be welded in on the bottom side of the spring bucket. Held them on with tech screws until welded. By doing this they will locate the same every time.
Installed my temporary spring locators on the rearend, both springs and raised the rearend to ride height while springs were pressing against the plates. Took a torpedo level, squared the springs front to back and side to side. With a Sharpie, traced around the outside of the spring where it contacts the plate.
Removed the spring and plate. To make it simple to locate center, I made a template. Center punched center and used a hole saw to cut the hole for the tubing.
Inserted the tubing and installed the plates back in the car. The tubing is pressed in, don't want to weld in until the rest of the parts arrive.
Passenger
Driver
Old Jan 8, 2012 | 06:11 PM
  #215
Heyfred's Avatar
Fabbed up some spring perches for the rearend. Made bolt on style because holes were aleady in place on the housing. Painted them with POR15.
Old Jan 9, 2012 | 01:53 AM
  #216
caviness's Avatar
build really turning out great.
Old Jan 10, 2012 | 11:06 PM
  #217
Heyfred's Avatar
Still waiting on jack screws, should be here friday. Getting the top plates fitted and ready for welding once the jack screws arrive.
Old Jan 11, 2012 | 07:53 PM
  #218
BAMALS1's Avatar
Nice work!
Old Jan 12, 2012 | 08:53 PM
  #219
Heyfred's Avatar
Finished cutting and fitting the roll bar mounting pads for welding. Once the rest of the parts arrive, it will take no time to finish this project.
Old Jan 13, 2012 | 12:36 AM
  #220
jtaylor16's Avatar
Hey I dont know if it was asked but did u ever encounter any issues with the front wheels the way you did them, i was considering doing that myself but wanted some feedback
