bracket racers please come in
I have found that a looser feeling converter (sloppy at low rpms) makes staging easier and is less sensitive to small staging rpm differences. It's not ideal for a street car, but we are talking bracket racing here.
good luck
Keep in mind that most shift lights do not work at lower rpms. I had to dig around to find one that would. The SW Ultra shift light was the ticket.
G/L
I always stage as shallow as possible to make sure I get consistant lights
I always run the car at full operating temp(for me is 190)
use the 2 step( I find if I launch off the converter its not very consistant)
use a weather station and keep logs
run your own race dont even look at the guy beside you unless he spun or something
always run bye runs or it the other guy redlights out the back door and log the data for the next round
if you log the D/A and all your runs you shouldnt break out anyway(I dial .02 faster than my round prediction)
I didnt mean you will crash or anything
I hae been racing Mod Et and index racing for about 14 years now
I run the stock computer and set the fans to run all the time and like I said run full operating temp all the time.I am not sure what you mean by "chase the temp" I have an obd LT1 so I know it does less than OBD2 in alot of ways
one other thing I forgot never use the stock tach or gauges buy aftermarket
run your own race dont even look at the guy beside you unless he spun or somethingalways run bye runs or it the other guy redlights out the back door and log the data for the next round
If your having trouble dialing in, dial up 3-4 hundreths and "judge" the stripe. It takes a lot of practice especially when theres big gaps in dial ins though.
Just my $.02
Derek
