10's NA?
Is it possible without gas or a blower?
Careful selection of components is the key. Weight reduction, a good track, and great weather are all too important as well.
My '02 ran 11.82 with an internally stock engine with no weight reduction (ok, so I pulled the spare tire and jack) and with stock gears. If you want to see how to do NA 10s with a heads/cam engine while remaining 100% perfectly streetable, stay tuned over the coming year.
I went 10.8 using the Hammer (c1)cam: 222/222
then 10.6 using the C2 cam: 224/224
Converter? Consider the Yank TP4200, it has worked for me and many others like gang busters
Also 10.8's have been done using the C1 and a Yank Super Thruster 3500 by a few folks.
Weight, track and TRACTION all part of the combo to consider, but it is VERY achievable.
Both on the 10.8's and the 10.6's after the runs at the track, I drove the car to work as it was my only mode of transportation.
Work on TRACTION and wait for some good weather. Choose parts that are PROVEN to work and work well.
Good luck.
Most of the cars I have seen run 10's with stock bottom end have been either super light and made okay power, or heavier like the 3350 example I gave above and made great power.
Raceweight is key... Your TA is 3700 raceweight stock with a 200 lb driver.
I know another car that just went 11.02 with stock heads and TB, but it was 3200 raceweight.
Most of the 10 NA folks I have seen have run cams like 226's, 228's, and 230's, and also the LG G5X2 cam.
As for a stall, how would anything more than 4000 do on the street? What about a 230-something cam? Still streetable.
I guess I forgot to mention this would still be my daily driver, and be a kick-*** street machine at that (not just Drag-ready)
I'm asking for too much, aren't I?
Another buddy has a 99 TA A4, and with a 382ci he got down to 11.13 with no weight reduction except for skinnies, but he also added a 6pt cage so he was probably a solid 3600 raceweight. Car still had the bumper supports and a/c and everything.
Owned!
btw, my 434ci was only pulled twice - warranty work
Little or No weight reduction on a N/A 346 running 10's?
Man that would be hard to beleive, i guess it would be possible.
If everything was perfect...maybe.
Word to wise, nothing about it would be simple or cheap for a 3700 pound race weight car to run 10's with the stock bottom end N/A.
Thanks for all the help guys!
James
Only thing missing from the interior is the rears seats and their belts.
On race day I pull the rear speaker panels, divider, and the passsengers seat. All take less than 15 mins to replace.
