Drag Racing Tech
manual brakes question
Old Feb 10, 2009 | 01:17 PM
TJ's Avatar
TJ
Originally Posted by brandoz28
anybody got pictures of the chrysler setup?
this is from advance website. orielys has the best price on them, but advance is picture friendly.
never seen one come witha clear tank on them, only black.
local chaiss builder odered a wilwood one time and it actually had the aftermarket parts store part # stamped right on the body.
Old Feb 11, 2009 | 07:55 PM
WhiteLTone's Avatar
its the jb-1 brake master for an s10 right? does it come w/ a pushrod assembly? if so would you reccomend making it adjustable? also this is the 24mm/36mm bore size correct?
Old Feb 12, 2009 | 12:19 AM
bigsticksupra's Avatar
sorry to sound dumb, but what does this manual brake conversion do other than get rid of the booster? will it work with stock ls1 brakes (abs has been taken out)?
Old Feb 14, 2009 | 03:09 PM
WhiteLTone's Avatar
it cleans up the engine bay, allows for more "room" also gives a more positive pedal feel i believe. im pretty sure dlove has manual brakes w/ stock ls1 brakes. im pretty sure it'll work fine, just need to allow more stoping distance.
anyone able to shed some light on my post above?
thanks
Old Feb 14, 2009 | 04:02 PM
veee8's Avatar
I have the Strange manual brake master kit, with stock LS1 brakes, works fine. definitely more pedal effort required though.
Old Feb 14, 2009 | 04:22 PM
nemss1's Avatar
how much more foot pressure has to be applied (how much harder) with manual brakes?
heard of some people having to use 2 feet coming to a stop down the dragstrip. dont like the sound of having to use 2 feet to stop
Old Feb 14, 2009 | 06:47 PM
JL ws-6's Avatar
Race your car!
I have aerospace drag brakes, a burkhart/strange master cylinder, and have no problems stopping a 3350 lb car from 142+
Yes there's a little more pedal pressure requires, but not so much that it's a problem. One foot and I have no issues.
Old Feb 14, 2009 | 07:16 PM
nemss1's Avatar
thanx JL, u have me convinced. going manual brakes
Old Feb 14, 2009 | 07:26 PM
JL ws-6's Avatar
Race your car!
Just get a the manual master from burkhart, it's got the right valving in it already, non need for a proportioning valve or any of that.
If you refab the lines on the car from scratch like I did with a brake line kit I got from quartermax, you can redo them with -3an fittings and tube nuts, and run teh lines nice and clean on the car. Use a 37 degree flare with them, and it's pretty easy to do.
Old Feb 14, 2009 | 07:32 PM
nemss1's Avatar
ya ill check out the burkhart kit. im also thinking about getting the SJM ABS delete and line lock along with the manual master
any other kits with the right valving so i wouldnt have to use a proportioning valve?
Old Feb 14, 2009 | 07:41 PM
nemss1's Avatar
^^^nevermind. checked out the burkhart kit and has the option for a line lock. really liked what i seen
Old Feb 14, 2009 | 07:51 PM
  #32
JL ws-6's Avatar
Race your car!
I'd do the burkhart with the line lock, and get a brake line kit from quartermax, fab the lines over from scratch and be done with it.
Old Feb 14, 2009 | 08:18 PM
  #33
nemss1's Avatar
i couldnt seem to find the line kit on quartermax website. is it just line with T-fittings?
  #34
cbra-klla's Avatar
how much lighter is a manual brake cylinder than a stock one??
Old Feb 14, 2009 | 09:01 PM
  #35
JL ws-6's Avatar
Race your car!
Here ya go:
http://rjracecars.com/details.php?pr...e%20line%20kit
Tabs to weld to the body, everything you need. That's what I used, and it was perfect.
The stock master with teh power booster vs the manual one is a good 15 lbs, and it cleans the engine bay up a TON.
Refabbing the lines yourself from stracth, is a TON cleaner then the ABS delete that uses the factory lines, and also saves another 10 lbs I bet, as you only have a single line going the back of the car that you can T off to each wheel.
I ran the lines on the body up by the fuel tank so that there's less crap on the rear, and you can drop the rear if you want without having to unhook the lines if you tie the calipers up to the car. I also ran the front line across under the radiator support, so that the k member can be dropped and changed without cracking a brake line as well. PITA, but it worked out pretty good, and it came out prety good IMO for a first attempt, especially considering I did it in january last winter and it was about 5 degrees outside, and all I had was my space heater in the garage at night when I was out there working (cold as HELL!)
Old Feb 14, 2009 | 10:07 PM
  #36
dlove's Avatar
thanks
Correct, I currently have the stock brakes. I have strange brakes front and rear on the way. I will be sure to let everyone know how it feels compared to the stock brakes.
Old Feb 14, 2009 | 10:31 PM
  #37
dlove's Avatar
Also, I bought some metric to -3 adapters, some -3 line, a -3 T, and a adapter for the master to a -3.
I didn't have to flare anything. I just undid the stock lines and put these in.
Old Feb 15, 2009 | 02:55 AM
  #38
nemss1's Avatar
thanx for the link JL. going with the burkhart kit and the quartermax lines
Old Feb 15, 2009 | 09:02 AM
  #39
Steve Burger's Avatar
LS1TECH Sponsor
We can get the line kit now as well.
Old Feb 15, 2009 | 03:47 PM
  #40
nemss1's Avatar
thanx burkhart. i will be contacting yall soon for the kits
