Drag Racing Tech
manual brakes question
Old Feb 7, 2009 | 11:52 AM
darrellk's Avatar
Default manual brakes question
im going to do this to my car is there a part number for a master cyl. that i could get at a parts store and make my own mounting plate. has anyone done this. or has anyone done this with the stock master cyl. any advise would be help full.
Old Feb 7, 2009 | 01:38 PM
Steve Burger's Avatar
LS1TECH Sponsor
We sell a complete kit. Our master is set up for the F Body bias as well.
Old Feb 7, 2009 | 01:50 PM
JUICED96Z's Avatar
Get a kit allready done like a Burkhart peice..... don't try and peice it together........ trust me....
Old Feb 7, 2009 | 02:08 PM
CanuckSS's Avatar
I made my own kit. I used a wilwood tandem master cylinder with part # 260-4894 that I purchased on ebay. I believe it is supposed to fit a chrysler, but I was able to fab it up without too much difficulty.
Good luck
Old Feb 7, 2009 | 10:22 PM
TJ's Avatar
TJ
a LOT of dragracers use an 89 dodge caravan master. its only 30 bucks from the parts store.
not sure on the bore size.
Old Feb 8, 2009 | 09:18 AM
veee8's Avatar
To me it was worth the $140 to but the complete kit from Eric at Midwest Chassis. It uses the Strange 1.25" bore master, which is like $120 from Jegs, so getting the complete kit is a pretty good bargain.
Old Feb 8, 2009 | 08:13 PM
Josh@KY-Turbo's Avatar
Burkhart Chassis for the win.
Old Feb 8, 2009 | 08:30 PM
pmbmax's Avatar
I use the strange but on cars in the past i have used the Chrysler with good results.
Old Feb 8, 2009 | 09:05 PM
WhiteLTone's Avatar
pmbmax, do you have to make an adapter plate for the chyrsler manual mc? im wanting to do a manual brake setup aswell.. my only concern is finding the correct bore size. I have aerospace drag brakes all around. any idea on what bore size would be correct for a swap like this? i noticed the wildwood one above is 1.0625 or 1-1/16" if that would work and all i have to do is figure out how to mount it, that'd be great
thanks
Old Feb 8, 2009 | 09:30 PM
pmbmax's Avatar
thanks
Yes you will have to make a plate and i had aerospace on my car befor i put the sathuff spindles . I have wilwood on it now but did not chane the M/C . do you have the booster off yet. The hole and bolt spread is big that is why you have to use the plate. also the hole in the brake pedal is metric so you will have to drill it out if you use a clevis . Its been a while sense i did one .
Old Feb 8, 2009 | 10:20 PM
WhiteLTone's Avatar
yes i have the engine bay completely stripped down to nothing right now, and i figure i will be able to make a plate to bolt the master to the firewall, but wasnt sure if theres a specific thickness needed, and as far as the pedal goes, that shouldnt be a problem, i have to pull the pedals out anyways, i used to have an m6 and still got the clutch pedal, so i should probably switch to an auto pedal set while im at it. i guess the next main question at hand would be is there a specific thickness needed in an adapter plate to maintain correct geometry, and the bore size on the chrysler is correct?
Old Feb 9, 2009 | 04:36 AM
JL ws-6's Avatar
Race your car!
Buy the burkhart kit, my brakes work great with it, and the whole thing went together easy.
Old Feb 9, 2009 | 11:40 AM
ndfrsd6's Avatar
just ordered a burkhart kit ....
Old Feb 9, 2009 | 11:54 AM
LS1TECH Sponsor
Thanks for the order.
Old Feb 9, 2009 | 01:13 PM
tomcowle's Avatar
The chevy S10 master cylinder is a nice option, plus you don't have to worry about the rod falling out and having no brakes.
Old Feb 9, 2009 | 03:05 PM
firefighting1101's Avatar
i got the burkhart kit also, and the burkhart manual steering aswell
Old Feb 9, 2009 | 05:21 PM
darrellk's Avatar
which S10 master cyl.
Old Feb 9, 2009 | 05:23 PM
WhiteLTone's Avatar
92 s10 manual master cylinder.
Old Feb 10, 2009 | 10:04 AM
TJ's Avatar
TJ
rod falling out? what happened? surely it wasnt adjusted right if it just popped out.
Old Feb 10, 2009 | 11:41 AM
brandoz28's Avatar
anybody got pictures of the chrysler setup?
