Drag Racing Tech
View Poll Results: which is the better shock?
strange single adjustable
71.43%
qa1 single adjustable
28.57%
Voters: 28. You may not vote on this poll
strange vs. qa1
Old Feb 9, 2009 | 09:29 PM
z28rob18's Avatar
Default strange vs. qa1
ok so ive searched but cant find it im an aweful searcher. id lik to know which ones better and y? vote in the pole and post y you voted how you did.
Old Feb 9, 2009 | 10:28 PM
ssvert99's Avatar
LS1Tech Premium Sponsor
Strange hands down. QA1 are imported and have had their share of issues. Strange is made in Chicago and i have never heard of any problems with them. believe it or not... Strange also cost less. its a no-brainer.
Old Feb 9, 2009 | 11:03 PM
Carbed4thGen's Avatar
Shoot i didnt know strange cost less go for them then! lol Just get a double adjustable and do it right!
Old Feb 9, 2009 | 11:10 PM
WhiteLTone's Avatar
jimmy- go get 2 sets of double adjustable fronts tomorrow.. you're closer to strange than me, and your cars faster.
Old Feb 9, 2009 | 11:21 PM
studderin's Avatar
strange fornts hear, getting there rear this year
Old Feb 9, 2009 | 11:23 PM
5.3LJimmy's Avatar
I did plenty of searching before I bought mine and most of the chassis sponsors on here recommend the Strange shocks over QA1.
Old Feb 9, 2009 | 11:48 PM
93_z28's Avatar
im going with strange because of all the good i heard about them and there like $149 a piece.
Old Feb 10, 2009 | 05:57 AM
I already have a set what do I need another one for
Old Feb 10, 2009 | 06:29 AM
defbob's Avatar
I was recommended Strange over QA1 as well. The chassis guys said that the Strange is more responsive to adjusting. "one click of the **** makes a big difference compared to 5 clicks to make a difference on the QA1", as was told to me.
Old Feb 10, 2009 | 11:12 AM
pmbmax's Avatar
I use strange but had QA1 i like the stange better. Just an issue i ran into WillyZ aka William C a buddy of mine had the **** on his QA1 go bad and we ask a QA1 tech guy at a race to help us out he said it would be over a 100 bucks hell the shock wasnt much more and they was very rude just an experance i had he may have just been having a bad day.
Old Feb 10, 2009 | 03:31 PM
z28rob18's Avatar
does strange have more then one spring choice lik qa1 does or just one spring? im gonna go with the strange there cheaper and better apparently so how can u beat that
Old Feb 10, 2009 | 04:05 PM
BMR Tech2's Avatar
Yes strange has several spring choices up to 325lb. For the price Strange shocks are the best value on the market.
__________________
T.C.
Sales Pro
BMR Suspension
(813) 986-9302
Like us on Facebook!
Old Feb 10, 2009 | 08:52 PM
T2SLS1's Avatar
whats the biggest advantage of a DA over a SA? Is it only for coming back town to earth "rebond" ?
Old Feb 11, 2009 | 11:18 PM
ssvert99's Avatar
Strange has the availability of the stock upper spring perch setup, or the drag race style setup.
the drag race setup uses a 2.5" id standard coil-over spring and eliminates the rubber spring perch. the coil-over springs are available in several lengths and weight.
the most common stock upper mount spring is a 300 pound, which Strange sells as well. the QA1 springs in 275# and 325# will work on the Strange shock if the 300 is not what you need.
i have the best deals on any shock/spring combo you need. pm me or call the shop.
Old Feb 11, 2009 | 11:23 PM
ssvert99's Avatar
all the single adj shocks are extension adjustable. this is the most common for the average street/strip cars and are the most cost effective.
the double adjustable shocks are compression and extension adjustable. the double adjustable shocks work well on cars that tend to get the front tires off the ground and have higher trap speeds. the double adjustable shocks when tuned properly can aid cars with downtrack traction, especially 6 speed cars that see alot of suspension travel during gear shifts.
Old Feb 12, 2009 | 07:03 AM
z28rob18's Avatar
so is it better on the 6 speed cars to have double adj all the way around? or more important in the rear?
and ill send you a pm when i need them. the sprint car team i work on is usin qa1's this year and will make a big purchase so if i can get a great deal with that purchase then i have to.
Old Feb 13, 2009 | 01:38 AM
ssvert99's Avatar
d/a shocks all the way around sure isnt a bad idea, but maybe overkill for some cars. all depends on how serious you are and what you want to spend. more important in the front if you are gonna do a s/a and d/a combo.
Old Feb 14, 2009 | 01:36 AM
Zero4488's Avatar
Restricted User
I have the QA1's all alround I have the front shocks and rear coilovers. I need to swap out my front springs soon....Too stiff for my liking....
Old Feb 14, 2009 | 09:27 AM
GrannySShifting's Avatar
Id disagree with that. I have a 6 speed car on drag radials and the double adjustable shocks in the rear are the biggest step forward in getting the car to work with the violent loading/unloading it sees vs a auto car, the front I run are single adjustable.
Every car we do starts with a single adjustment in the front, and if its a stick car or limited tire auto car a double in the back.
Old Feb 14, 2009 | 09:52 AM
z28rob18's Avatar
i think when i buy im goin to stick with s/a because its simpler i dont know that much about suspension tuning and think d/a would be alot to learn. ssvert99 i pm'd you for a quote.
