Lightweight Battery or Rear Mount???
Please show me a mid/high 10 second car
that runs a big drag radial, that absolutely NEEDS a battery in the back for weight transfer. I'm sure at the 600rwhp mark they NEED it in the back for the weight, but then again, they'd be in the 9's anyway and it would be required to pass tech.
Most guys who get serious about their cars and gut them for drag racing, end up taking WAY more weight out of the front than they do out of the back. And they also USUALLY end up ditching the 160lb 10-bolt and going with a 9-inch or a S60 or a 12-bolt, which adds at leats an additional 30-40lbs right on the tire.
That, plus the potential headaches from the little battery aren't worth it. I know "my car starts fine with it" and blah blah blah... but I guarintee the first time that little turd dies and leaves ya hanging you'll be hating life and wishing ya never bothered with it.
I
I hope you put the car on scales before and after, and measured your fender gaps on all 4 corners to make sure the car is sitting the same with the weight still distributed the same, if not get ready to start over.
