Drag Racing Tech
How to delete Vats? Not bypass...
Old Feb 25, 2009 | 08:06 PM
TasTe_GOOD's Avatar
Question How to delete Vats? Not bypass...
I'm just wondering how to remove vats completely. I am cleaning my wire harness and do not need vats anymore, so can I just remove the box and trace/remove all the wiring to the vats box?
Or is there something special that I have to do?
Btw, I did a search and I came up with only bypasses and didn't feel like looking past more than 5 pages of search listings...
Old Feb 28, 2009 | 07:55 PM
Happytokr's Avatar
The VATS run to everything! Without the box nothing will work not even the fuel pump! I had that problem with my car. The VATS went out. I did the byass and all systems go. I would not remove it if I where you!
Old Mar 1, 2009 | 04:00 PM
1toDV8's Avatar
VATS can be removed but only by a tuner. If you have access to HP tuners it can be removed with that programming software. LS1 edit can as well.
But simply removing the body control module will disable the engine computer. the 2 computers talk back and forth to each other when you turn on the key. They each look for VIN code info and once they varify that the VIN numbers match, then the engine can start. You either have to program it out or use a bypass mudule to eliminate it. Or by an aftermarket PCM for the engine.
A bypass module just fools the computer into thinking there is a body control module and its ok to start the engine.
I have one in mine, and I've got it setup on a rocker switch hidden in the car so I can disable the engine PCM when I'd be worried about a theif. it would take quite a bit of time for the theif to figure out tha the PCM is disabled and how to enable it. Which would probably frustrate them into giving up!
Old Mar 1, 2009 | 04:21 PM
DrkPhx's Avatar
As mentioned above you can simply disable it using tuning software like HPT or EFILive. Quick and simple.
Old Mar 1, 2009 | 07:30 PM
GTFORMULA's Avatar
My key lock cyliner went out. I turned the vats off with hptuner and still wouldnt start. I have to put resistors in line of the vats to trick it.
Old Mar 2, 2009 | 12:57 AM
kp's Avatar
kp
Disabling the VATS in the PCM will let the car run, the BCM lets the car start. If you turn of VATS in the PCM and ground the wire from the BCM to the starter relay the car will both start and run.
Old Mar 2, 2009 | 10:52 PM
WhiteLTone's Avatar
kp does this apply to obd1 cars as well? im worried i'll have issues starting my car, i dont have a factory pcm anymore. i'm running a carb'd ls1 using msd lsx box.
Old Mar 7, 2009 | 12:00 AM
nemss1's Avatar
is the starter relay in one of the fuse junction boxes under the hood?
Old Mar 7, 2009 | 12:19 AM
kp's Avatar
kp
Have no idea on an LT1 car to be honest.
Yes, its by the left headlight.
Old Mar 7, 2009 | 12:24 AM
nemss1's Avatar
where do some people ground this wire on the starter when deleting VATS???
Old Jan 12, 2010 | 10:32 PM
CaptainDirtymax's Avatar
will this work for 3rd gen cars too??? i haven't been able to start mine in almost 2 years because of VATS, and i don't want to have to pay nearly $600 for the Chevy dealer to install a new one. if i could just bypass it, i'll be happy.
Old Jan 28, 2010 | 10:03 AM
buicklover's Avatar
Thumbs up You can get rid of VATS very easily
This is what saved my car and my money (that I didn't have!). Here is a write-up on how to do it all yourself. It will bypass the VATS system entirely, you will not hear about it anymore and it will not own your car anymore!
http://newrockies.ca/vatsbypass
Old Apr 9, 2011 | 10:38 AM
rick1953's Avatar
Has anyone have feedback on the newrockies.ca/vatsbypass Thanks Rick
Old Mar 14, 2021 | 04:38 PM
KletusKlank's Avatar
This is not a write up for anything this is a sales pitch link to get 289 dollars out of someone. There are much cheaper options out there do not click on that link it is a waste of time unless you just want to spend 300 bucks for a bypass when you can get them on eBay way cheaper.
Old Mar 17, 2021 | 10:45 AM
Old Geezer's Avatar
Good to see you following up on a 10 yo thread.....
Old Mar 26, 2022 | 02:31 PM
Work_truck6's Avatar
I know old thread, ground wire for bcm or another wire (which one please)
Last edited by Work_truck6; Mar 26, 2022 at 02:32 PM. Reason: Autocorrect screw up
