Bias-ply vs. radial fronts
I've been searching all morning and am still looking for a more definite answer. I just bought a pair of Greg Weld 15x3.5 fronts and summit stars 15x8 for the rear. I am going with the M/T 275/60/15 drag radial for the rears but am undecided on the fronts.
I have heard you shouldn't mix radial and bias-ply tires but I would feel safer running these
http://www.jegs.com/i/Mickey+Thompson/672/1573/10002/-1
than running a cheap 165 radial.
I also don't want to pay the $$$ for the M/T S/R either.
Does anybody run this setup? Any other suggestions?
Thanks in advance
Thanks in advance
https://ls1tech.com/forums/wheels-ti...-bankrupt.html
I heard about them here, but I think they are sold out now.
You will burn up the bias-ply tires much faster driving them on the street. I've heard that a lot of guys only get 2000 miles out of them and whatnot. You will also save a significant amount of weight running a bias-ply versus a radial up front. I ran Kumho 165/85r/15's for 2 years and recently switched to a MOROSO bias ply. The Kumho's are exactly 10lbs heavier apiece which is all unsprung weight, which is freakin huge. 20lbs off of the nose for about $225-$240 is well worth it to me.
They are the Greg Weld 15x3.5 from Summit.
As for the back I would run bias ply, especially with you ever spray the car.
