Roll Cage Padding Opinions
I recently bought some JAZ padding which is SFI 45.1 rated, it was too small for my cage pipe diameter. Which do you guys order, the simpson padding looks to fit 1-2" pipes.
Also do most of you go with the SFI 45.1 (although not needed till 180mph) for added safety or do go go with other?
I think the half circle padding seems to be the best choice.
most 45.1 stuff is the half-moon stuff...never a bad idea to run since its rated for higher impacts and flame retardancy...
you can find stuff to fit 1 5/8 anywhere
I put the Simpson 45.1 stuff in recently, it is half moon shaped like Fireball said and has adhesive backing so you don't need zip ties. It fit my Wolfe bar fine and I used the highest rating it in case I gonk my head during street driving. Good luck,
Larry
Larry
Problem solved, i ordered this stuff. Best of both worlds. Just a little bit bigger.
