How much 60ft improvement with adjustable shocks?
the truth is, double adjustable will always help if you need more traction. how much? its impossible to tell unless we have all the info on the car, and the expectations of the owner once the DA shocks are on it. what tire? what ET/MPH?
if you are not spinning, double adjustable (or any other shock) wont help you. as long as you can apply all the power you have, you dont need to change a thing. the moment you want to come out with more power, then lets address the issue. not spinning is not good for 60' times either, as you need to maintain wheel speed for best results.
I dont have double adjustable shocks (or single adjustables!) and go 1.3 60' times in a heavy car. to the OP, based on what you are saying, i doubt you will need double adjustable shocks.
This is not to say the money couldn't be more wisely spent somewhere else, but only to get an actual answer of whether he or I for that matter would benefit from them.
in any event, if the OP advised on his combo and his goals, we could help him out more.
