daily 9 sec car
my 402 @ 3350 goes 9.5x on a 150 shot, if the a/c, ps and heat were still in it the car would be abotu 3500, and it would still run a 9 second pass I'm sure.
You put an alum 434 together with good heads and about 11 to 1 compression, 4l80 so ya still have a streetable od tranny, spray it with 150 maybe 200 tops and it shoudl have no problems.
The safety stuff will add alot of weight, if you can get the car to 3500 with the cage and whatnot it won't be that bad.
Just have to have the $.
Mike R, has a street driven CARTEK 402 4L80E with a rear mounted turbo's that went high 8's on Drag radials. He drove that car from NJ to Florida and back, and on the day it went 8's he drive it over 60miles to the track on the same radials he ran the number on, the pumped up the pressures, and drove 60 miles home.
Yes Turbo's are more expencive, but there are no bottles to fill, and the power seems to be coming out of the ears. More than enough to run a 9 second pass... clearly... With a well designed setup, streetability is perfect as well.
