Drag Racing Tech
what strenth battery for my compression?
Old Apr 29, 2009 | 11:20 PM
383lt1impala's Avatar
Default what strenth battery for my compression?
I want to buy a lightweight battery (its going to say in the enginebay) and I see that a lot of them have a low rating of cranking amps. And I have 12.56 compression and I wanted to see what's about the minimum I should go in ca or in cca. I don't want to have jumper cables handy all the time. Thanks for any valuable imput.
Old Apr 30, 2009 | 09:15 AM
Bitemark46's Avatar
My $.02. You may want to also take into account the starter. Even if you have enough juice to power it the starter may not be up to the task. Then again I don't know how strong GM starters are.
But to answer your question I'd get atleast 675 cca or more.
-Mark
Old Apr 30, 2009 | 11:43 AM
I 4got to add its the stock starter.
Old May 1, 2009 | 08:08 PM
greatskiiiier's Avatar
starter is going to be your first and big issue, the battery will be fine with anything over 700cca
Old May 1, 2009 | 10:08 PM
Black Sunshine/ 00SS's Avatar
I can tell you for a fact, that the 6.0 starter cranks over with more power, than the F-body one, or the vette one. i know, I changed a few in one day, because I kept overtightening the electrical bolts, and they are very frail.
I like the Yellow top Optima...
You could always take your stock starter someplace & have them rebuild, and beef it up to crank out more juice.
Old May 1, 2009 | 10:36 PM
99TransAmLS16Spd's Avatar
I was wondering the same thing as the OP. I notice that most of the lightweight batteries are only rated at 225-300 cca's iirc.
Old May 10, 2009 | 03:00 AM
Wicked94Z's Avatar
curious as well, also running 12.5x compression
Old May 10, 2009 | 01:29 PM
Daredevil_TA's Avatar
I know some of the braille batteries have CCA's in the 500's and are pretty light
Old May 11, 2009 | 06:26 PM
cbra-klla's Avatar
Wonder how long the stock starter will last with 13.75 to 1 compression
