What A3 shifter to use w/o center consol?
I am considering putting an th400 RMVB w/ TB in my car and would prefer to get rid of the center consol.
Does anyone have any pictures of a shifter installed w/o the center consol? If so, can they tell me what modifications where made to make it fit flush w/o a gap in the floorboard where it attaches to the transmission?
I actually just did this. I did go from six speed to a RMVB TH400, so i did have to fab a plate to cover the hole. I also removed the E-brake assembly and airbag module. I used the TCI outlaw shifter, i'll try to get some pitures when i can. Its a nice clean looking shifter and functions very well. Only thing i need to do now is get some new carpet to cover up the exposed areas of the console
No, although it is very nice.
I wanna ditch the center console and go with a flush direct floor mounted kit.
I would really like to see some pictures of Mike's setup with the outlaw picture in the car.
Also, ndfrsd6... that looks very nice. However, I would like something with a cover though so that the metel isn't showing.
Very nice guys. Those look great.
Camaro396/Mike-- Why did you decide to go with the Ratchet shifter w/ the pistol grip?
ndfrsd6-- Why did you decide not to go with the ratchet shifter?
Thanks again guys, this forum is great.
Its not a ratchet, i dont like those. Its a gated style. When your in first squeeze the lever pull to second, release the lever and pull to third. There is a gated plate in there that stops you from going 1st to 3rd when the lever is pulled.
Out of curiosity, what do you not like about the ratchet shifters?
Just for clarifications sake, the reason I have to pull the handle to make the shift is because I have a reverse pattern VB and a forward pattern gate..
Park --->pull-->>go into reverse -->pull--> go into nuetral etc. to go back you would push the shifter and release, everytime you push it, it will go the other direction..
A gated shifter requires you to pull a lever to engage stops to prevent from going to 1 to 3 for instance...
