Drag Racing Tech
Pulling the Front Wheels
Old May 7, 2009 | 08:33 AM
ElkySS's Avatar
Default Pulling the Front Wheels
whats the lowest hp you have ever heard of someone lifting both front wheels at? not necessarily sky high, just both off the ground.
Old May 7, 2009 | 08:37 AM
zracer323's Avatar
I've seen a 17sec S10 pull one wheel off the ground launching. Just proves that high hp is not necessary
Old May 7, 2009 | 08:51 AM
BlackScreaminMachine's Avatar
Internet Mechanic
I make 380 and the car is heavy. I have a vid on a camera which ever so slightly showed a OEM WS.6 17" rim pick up off the ground. I was impressed when my car did it on a Nitto, but I really picked up when I put the bias ply on and a set of skinnies.
https://ls1tech.com/forums/eastern-m...ay-new-pb.html
Feel free to see the vid!
Old May 7, 2009 | 11:04 AM
tektrans's Avatar
I'll bet you can do it with the stock motor and the right suspension, tires etc.
Old May 7, 2009 | 11:57 AM
Internet Mechanic
Or enough weight out of the front end
Old May 7, 2009 | 12:15 PM
z28rob18's Avatar
or enough gear in the rear and get it to hook
Old May 7, 2009 | 01:20 PM
GIZMO's Avatar
True. When I was running IHRA Pure Stock with my untouched LT1 I would pull both front tires about 3".
Old May 7, 2009 | 01:43 PM
tee-boy's Avatar
I would vote for:
correct susp geometry, enough tire, big enough stall
Old May 7, 2009 | 01:47 PM
Internet Mechanic
Originally Posted by tee-boy
I would vote for:
Adding to that, Rear end gearing, and weight stubraction, from the front mostly.
Old May 7, 2009 | 01:52 PM
WS6TransAm01's Avatar
CARTEK Racing
I've pulled the wheels on "stock internals" cars with slicks on the back, both had 4.11's and had some weight reduction.
Old May 7, 2009 | 02:23 PM
tee-boy's Avatar
Default agree
not starting an argument, but I would think stock weight on front could be made up with a change in rear suspension geometry. Gearing tends to go along with tire and converter.
Old May 7, 2009 | 03:31 PM
98blueSScamaro's Avatar
yea its really all in the suspension and a M6 or A4 can do it just takes seat time.
Old May 7, 2009 | 03:47 PM
nite ryder's Avatar
a good amount of torque will also help you pull the wheels. hp helps more on the top end and torque is your hole shot
Old May 7, 2009 | 03:59 PM
mike c.'s Avatar
I was running 12.2's and on the video I lifted the stock ws.6 tires just a bit. I was making 380hp then.
Old May 7, 2009 | 05:15 PM
Firehawk441's Avatar
Yup
Old May 7, 2009 | 06:18 PM
tee-boy's Avatar
Default torque converter
that's why you get a torque converter with a high stall and high stall ratio. tougher with a m6 (it can high stall but it has a stall ratio of 1:1) so you're stuck with whatever the motor can make on its own.
Old May 7, 2009 | 06:41 PM
Internet Mechanic
I agree but taking stuff out or relocating = neglible cost.
I learned that trick running classes that had weight requirements. You cant be under a certain amount but you can remove it and add balast.
Old May 7, 2009 | 07:50 PM
01sscam's Avatar
Man-Crush Warning
Why do you want to "pull the front wheels"
Old May 7, 2009 | 07:56 PM
SmurfLSX's Avatar
I agree.
Old May 7, 2009 | 07:57 PM
waterbug1999's Avatar
spray will do it.
