Drag Racing Tech
I wanna lose some weight.. 3966lbs
Old 05-14-2009, 10:28 PM
'Trust''s Avatar
Default I wanna lose some weight.. 3966lbs
My car needs a diet, here is the breakdown on whats added over factory:
Entire D1-SC setup (headunit, twin IC's, piping etc.)
Alkycontrol Meth Kit (single nozzle)
3 Core Radiator
6 point Wolfe w/swingouts
Moser 12 bolt
BMR Heavy Duty Anti-roll Bar
Spohn lower control arms, panhard, SFC's, relocation brackets
Fuel system
It's an aluminum block 396 car too, so nothing really added there.
The car has zero weight reduction and with me in it (I weigh 175), the Bogarts with 28 M/T DR's it weighs 3966 lbs with 1/2 tank of 93.
Anybody have any ideas of what I can do to shed a few hundred pounds off it? It is a street car so I don't want it super loud on the inside (dumped 3" magnaflow race mufflers), but other than that, I don't care. Thanks!
Old 05-14-2009, 10:40 PM
Sharpe's Avatar
Front and rear bumper supports? I think that would be about 80 lbs. Air bags are really heavy too. Might be able to kill off about that much weight again. Relocate battery in the back so at least the weight is in a better place.
Take a look in the sticky for all the weight lists.
Old 05-14-2009, 10:41 PM
Sharpe's Avatar
https://ls1tech.com/forums/drag-raci...y-updated.html
Old 05-14-2009, 10:50 PM
'Trust''s Avatar
Cool thanks, you mean the metal bumper supports, not just the foam/egg crate stuff?
Old 05-14-2009, 10:52 PM
Sharpe's Avatar
Not sure as I have not yet done it. I'm going to when I remove the facia to have it painted along with the hood.
Do a search for, like, "removing bumper supports" or something; there are a few long threads about it with pics, etc.
Old 05-14-2009, 11:02 PM
'Trust''s Avatar
I'll look it up for sure, I just don't want the bumper to wave around like a few that I've seen
Old 05-14-2009, 11:56 PM
letsrunem's Avatar
Yeah, look at the list and decide how far you want to take it.
Old 05-15-2009, 02:01 AM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
'Trust'
Burkhart makes a brace to support the front bumber to keep it from sagging after you remove the factory stuff.
Old 05-15-2009, 02:28 AM
RedsrtAk's Avatar
The whole bumper support, it is pretty hefty. You will loose the fog lights because they are connected to the support. Just FYI
Old 05-15-2009, 07:26 AM
TS6
TS6's Avatar
What I would do on a street car is remove the bumper supports, use a lightweight battery, tubular K, ditch the back seats (unless you need them), lose the TCS/ABS, and use CM on the suspension stuff whenever you can.
I have my iron block/D1SC car down to about 3100 w/o driver, but I removed the HVAC, installed the speedglass back window, installed manual drag brakes, and have a TH400.
The TRZ rear sway bar is really nice, it will drop alot of weight if you're using one of the spohn or BMR drag bars.
Bottom line is once you get past the "free stuff" (bumpers, spare/jack, backseat, etc) be prepared to either make sacrifices to your comfort or sacrifices to your budget.
Old 05-15-2009, 07:52 AM
Internet Mechanic
BlackScreaminMachine's Avatar
It really depends if this car is a street car that sees the track or a track car that sees the street. If you roll around with the 6 point all the time and the bar is protecting your side is there, then you can remove the door bars. You can put a Burkhart bumper support, remove HVAC/Stereo.
Lightweight carpet etc etc, there is alot there you can do. Just Depends on your tolerence.
Old 05-15-2009, 09:33 AM
98silvertacrbn's Avatar
Not if you will cut the upper part off the bumper you can leave a thin strip of the metal that retains fog lights and lower bumper supports. I have done this with my last two cars and it works great and only weighs two or three pounds
Old 05-15-2009, 10:09 AM
Z28/2002's Avatar
Burkhart also offers the provisions to keep the foglights with their brace
Old 05-15-2009, 10:12 AM
Internet Mechanic
Agreed, also a buddy who has done this made it himself.
JLws6, our Moderator. I personally help out with the car. its a worth while mod.
Old 05-15-2009, 10:44 AM
WS6 SRT-8's Avatar
How much weight does each of these knock off? I like the idea of losing the weight, but not the fog lights.
Old 05-15-2009, 10:52 AM
My way is free and i think it comes in at 16-20 lbs no sag yet
Old 05-15-2009, 10:57 AM
WS6 SRT-8's Avatar
Got any pics of the cut support before you put the bumper cover back on?
Old 05-15-2009, 11:52 AM
SUCK MY SS's Avatar
just weighed the passenger airbag, driver airbag and srs control module for the fbody and all three come in at 20 lbs...
Old 05-17-2009, 02:17 PM
Ego Killer's Avatar
WOW ! 3966lbs I thought mine was heavy at 3080
Old 05-19-2009, 02:53 AM
letsrunem's Avatar
Seriously?
